B18 Block Questions
Old Sep 10, 2009 | 10:25 AM
White99EK's Avatar
Default B18 Block Questions
I've been going back and forth between building my stock d16y8 for turbo or an N/A build but a friend of mine offered me a b18b block and b16a head for a price i couldnt pass up so it looks like i will be doing an ls/vtec.
In the all motor dyno thread, i noticed some people boring out to 81.5mm and some to 82mm, so my first question is 82mm still safe to bore to with the cylinder walls being too thin? Second, I see some people running the P30's or the PR3's. Are these good choices or should I step up to forged? Looking for around 12:1 CR. And then which rods can I use without machining the piston to fit? Eagles?
Goals for this build would be at least 200whp dialy driven. Possible?
Old Sep 10, 2009 | 09:05 PM
christmastree's Avatar
Default Re: B18 Block Questions
you would be just fine with the p30's. 200hp is way acheivable on the lsv. cam, upgrade your valvetrain and tune and you are set. that is what i am going to use on my build i am about to start.
Old Sep 10, 2009 | 09:18 PM
ek9poormanr's Avatar
p30's will work.Get a good header,cams and tune.There's alot of builds on here you could get a idea off of to see what parts and setups that will get you to 200hp.
Old Sep 10, 2009 | 10:21 PM
White99EK's Avatar
Yeah i've been reading the all motor dyno thread alot to get some ideas. i'm just not sure if i should go with the p30's or a set of forged pistons. And if I do go with the p30's, is it the LS rods that connect to them with no machining?
Other than ebay, where's a good place that everyone likes to buy them at?
Is it safe to go to 82mm or is 81.5mm good enough?
Old Sep 12, 2009 | 10:03 PM
White99EK's Avatar
Anyone?
2JZGod
Engine Machining & Assembly
Sep 22, 2016 09:49 PM
lowlownsloslo
Apr 24, 2016 07:05 PM
killacam661
Nov 26, 2007 12:35 PM
Rooftop voter
Feb 13, 2007 04:49 AM
eg2turbo
Feb 16, 2003 10:02 PM
