GSR Blades Specs Request.
Old Sep 10, 2009 | 09:34 AM
Romo Pyro's Avatar
Default GSR Blades Specs Request.
Just trying to find out a bit more about the GSR Blades:
1) 15" or 16" Diameter?
2) 5.5" or 6" Wide?
3) Weight in lbs?
4) Recommended Tire Size?
TIA.
Old Sep 10, 2009 | 09:45 AM
TOO MUCH TORQUE's Avatar
Default Re: GSR Blades Specs Request.
1. they are 15 inch
2.what are you asking?
3.they are 16.3 pounds each
4.195/55/15 is the ideal size, next size is 205/50/15
Old Sep 10, 2009 | 09:47 AM
Romo Pyro's Avatar
Originally Posted by TOO MUCH TORQUE
1. they are 15 inch
Ok thank you, I was asking how wide they were, sorry for not clarifying.
Old Sep 10, 2009 | 10:29 AM
JdmTypeRdc2's Avatar
i believe they are 15x6 if im not mistaken
Old Sep 10, 2009 | 10:59 AM
keepinitrehaal's Avatar
they are 6.5 inches wide.
Old Sep 10, 2009 | 12:41 PM
kwinn88's Avatar
My blades are sick!!!
Old Oct 27, 2010 | 10:33 PM
unknownally's Avatar
I'm running 195/50/15 and they are perfect IMO.
Old Oct 28, 2010 | 02:07 PM
TwoFaced's Avatar
As a note...tire size can throw off your speedo a little bit. Don't know if that would be a bother to you but just a heads up.
I'm running 195/50/15 on my SI rims...I'm content.
Old Oct 28, 2010 | 03:46 PM
195/50/15 is a horrible size.
What is the point of running a lower side wall yet keeping the tire the same width. Not to mention it also throws off the speedometer quite a bit.
An ideal size to upgrade to would be 205/50/15, and it will not throw off the speedo either. You get a wider tire, lower profile sidewalls, and looks way way better.
Old Nov 3, 2010 | 05:54 AM
nsxtasy's Avatar
H-T Order of Merit
WRONG. They are 15x6.
The recommended tire size depends on what car they're mounted on. On an Integra, 195/55-15 or 205/50-15 are best, as noted above. If you put them on a CRX, del sol, or '95 or older Civic, then 195/50-15 is best.
Old Nov 3, 2010 | 09:43 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I prefer 195/50-15 on my stock GS-R wheel. I can live with the speedo error. You get an effectively higher final drive ratio, and more wheel well clearance if your car is low.
I have 195/55's on there now and I hate them. They scraped the fenderwell seam on driveway slopes before I banged/flattened the seam to get it out of the way. My 195/50's never scraped or rubbed, ever. And I'm on stock GS-R springs with Koni shocks set to the lowest perch height. You wouldn't think there would be any clearance problems with 195/55 tires but there was.
It's personal preference really. Weigh the pros and cons of each and decide what you want to use.
Old Nov 3, 2010 | 09:54 AM
TwoFaced's Avatar
Old Nov 3, 2010 | 10:43 AM
nsxtasy's Avatar
H-T Order of Merit
Since they're smaller than the stock size, they look kinda funny. Also, fuel economy is less. And yes, you'll have speedometer error AND odometer error (it will pile on miles at a slightly higher rate). I've never had any rubbing with 195/55-15 tires (or 205/50-15 tires) on either my GS-R or my Integra Type R. For all these reasons, I would never use undersized tires on either of my Integras, but as you say, ...
Old Nov 3, 2010 | 08:04 PM
Community Builder
Always looked fine to me...
Old Nov 4, 2010 | 06:54 PM
98lscoupe's Avatar
those are fat fives
Old Nov 4, 2010 | 10:31 PM
^^^topic changed from blades to recommended tire size for 15 inch wheels if you didnt notice.
The pic was put up to show the difference between 205/50/15 and 195/50/15
Old Nov 5, 2010 | 05:58 AM
Community Builder
exactly, and both wheel types have the exact same specs except for very slight weight difference.
Old Nov 8, 2010 | 09:20 AM
nsxtasy's Avatar
H-T Order of Merit
Wow, Patrick, what's with the tiny dinky tires in that photo?
Old Nov 8, 2010 | 09:24 AM
Community Builder
perfect size tire IMHO
My damn 195/55's look like balloon tires.
Old Nov 8, 2010 | 09:46 AM
nsxtasy's Avatar
H-T Order of Merit
Well, MY 195/55-15 tires look absolutely perfect!
Old Nov 8, 2010 | 09:49 AM
Spawne32's Avatar
205/50/15 ftw
Old Nov 8, 2010 | 09:51 AM
vtecdc4's Avatar
Originally Posted by 98lscoupe
those are fat fives
didnt really like fat fives all that much
but that teg is sexy.
Old Nov 8, 2010 | 10:03 AM
Community Builder
heh thanks, if only it still looked that good
hard to believe that pic is from 6 years ago, when the paint was minty fresh.
I dunno if it's just my 195/55 tires or what but they look friggen huge
Old Nov 8, 2010 | 10:57 AM
Original.'s Avatar
195/50/15
195/55/15
205/50/15
Yeah 195/55/15 is huge. I had those before and I took off chunks of my tires.. 205/50/15 is good, but I still rub when I take corners or hit a bump. 195/50/15 is perfect, no rubbing or anything at all. (This is only true if you're tucking tire.)
Old Nov 8, 2010 | 11:07 AM
Community Builder
I'm not even tucking tire (see above) and my 195/55's were rubbing on uneven driveways until I hammered the fenderwell seam flat.
