JDM black housing headlights
Somebody stole my corners for my JDM black housing headlights. I need both corners. I called PasswordJDM and they don't have any. I checked eBay and they don't have any.
Will Depos fit on the JDM headlight?
Do OEM Headlight corners (Clear or Amber) fit on the JDM black housing headlights? Thanks.
It'd be to much money and you'd have to wait quite some time to get a jdm part assuming you could.
I am pretty sure that jdm corners are not interchangeable w/ usdm ones such as the ones on eBay. The jdm ones only have one bulbs vs the 2 that the us version has.
Do you have your old stock headlights to compare? However, I think the the corner lens itself will fit its just that the back of it is different.
Damnit. I need to fix this because the car looks horrible missing both corners. If I don't find the corners in a week I'm just going to buy another set of JDM Black Housing Headlights and sell my headlights w/o the corners.
OEM corners will fit just fine, The JDM lights are bulkier in the back (reason why you have to trim if you use DEPO corners on DIY headlights. So the smaller OEM will work.
Yeah. I have to look on eBay and get some depos. Last "Depos" I bought weren't Depos and I didn't have the patience nor time to return them.
