easiest way to get tranny back on after doing a clutch??
Old Sep 10, 2009 | 06:03 AM
OBDII Integra's Avatar
Default easiest way to get tranny back on after doing a clutch??
I installed a clutch and flywheel last night with motor still in car, dropped the tranny put the parts on, but when I was tryign to get the tranny back onto the block I was having ALOT of trouble getting it back on, i had a clutch alignment tool, and its just so awkward to ge tit back up there, do any of you have suggentions or tricks that you have learned to match it up to the block easy?...Thanks
Old Sep 10, 2009 | 07:31 AM
Default Re: easiest way to get tranny back on after doing a clutch??
any info would help, thanks guys
Old Sep 10, 2009 | 08:51 AM
suspendedHatch's Avatar
Tranny jack. Harbor Freight.
Old Sep 10, 2009 | 08:52 AM
sitinduk's Avatar
I swapped my clutch and tranny a couple month back. It was a real pain getting the tranny on.
Your using a floor jack to lift the tranny, right? Also, did you put the dowel pins in the tranny? I put a little grease on mine.
As you lift it, make sure it doesn't bind on the passenger side axle or the wiring harness.
Old Sep 10, 2009 | 09:40 AM
kentwat's Avatar
I second the dowel pins. I didn't know they were removeable and the new tranny had it in the opposite side. Thankfully I noticed it. Patience is the key and a jack that you do not have to fight balancing the tranny on.
Old Sep 10, 2009 | 11:11 AM
ls/v_dave's Avatar
New User
get the imput shaft as close to align as possible and what i did that works for me has some kick it in from the passenger side. it wont damange anything
Old Sep 10, 2009 | 11:55 AM
pinoiballer01's Avatar
New User
remove the axel that is connected to the block. it is a lot easier to put the tranny back without it. the only thing you need to align is the clutch.
Old Sep 11, 2009 | 06:04 AM
Yeah im using a jack, and the car is on a lift as well, Even when using the jack and with an aid from a friend, it still is so awkward getting it on with the tight area its in. it seems like its hard to see if the input shaft is going in straight on.
Old Sep 11, 2009 | 09:29 AM
Stasher1's Avatar
did you align the clutch??
Old Sep 11, 2009 | 10:32 AM
VIDC2's Avatar
its always a bit of a pain, but keep at it! you can do it bro trust me
Old Sep 11, 2009 | 11:17 AM
OH_1fstgsr's Avatar
I just put my D-Series trany back in my Del Sol by myself. So it can be done.
My car was up on jack stands front and rear.
I put one of those old plastic milk crate boxes on the floor under the trany location. Then pick up the trany placed it on the box. Adjusted the motor with a jack. Then leaned over and fender, lifted a little and rotated the trans to get the dowels lined up.
DO NOT try this if you have back problems of any kind.
Old Sep 11, 2009 | 11:46 AM
8zero8's Avatar
so youre using a lift, a jack, and a friend? wow! I suggest finding someone that knows what they're doing before u hurt yourself
Old Sep 11, 2009 | 11:47 AM
8zero8's Avatar
maybe u got the wrong clutch
Old Sep 11, 2009 | 12:25 PM
Romo Pyro's Avatar
get some kind of a hoist, then get under it and fiddle with it. it'll go in eventually, or if your big enough, screw the hoist, and just lift it.
Old Sep 11, 2009 | 12:29 PM
8zero8's Avatar
take the clutch back off and make sure u got the right disk first.. just to be sure
Old Sep 11, 2009 | 12:31 PM
95dc2teg's Avatar
easiest way is to get urself and two other friends. one to lift from the top and the other two on the bottom, lifting and aligning. 2 friends and I seriously can get it in, in like 20 seconds.
Old Sep 11, 2009 | 03:19 PM
Stasher1's Avatar
i agree
i had mine in by myself in like 30 min.
it was a ****ing bitch but i did it
Old Sep 11, 2009 | 08:56 PM
gourley's Avatar
I had made 6 inch long rods that I stick in the block where the tranny bolts go and then I place the trasnsmission on the rods then slide it in. Very very easy to do it that way.
ftrms
Mar 5, 2009 06:23 AM
chrisyaj
May 13, 2008 03:15 PM
JDM_SOHC
Sep 18, 2006 08:49 AM
13link EG
Jul 30, 2005 08:53 PM
spladam02
Dec 9, 2002 06:05 AM
