Car Vibrates between 25-35 mph - NEED HELP
Well, i have a 1999 Honda Civic Si, recently replaced both axles new, and now the car vibrates between 25mph - 35mph,
under 25mph - no problems
when its 25-35mph - vehicle vibrates
over 35mph - hardly noticeable slight vibration...
it is only when accelerating.. the wheels should be balanced cuz they are about 2 months new...
what could be my problem...
bad axles or needs alignment?.. the car is out of line, and does glides towards the right...
i dont know how bad your vibration is but...
i broke the passenger side halfshaft at a recent autox. the oem one had the damper ring on it also where the axle snapped. i put a napa one on and it didnt have the rubber ring on it. when i first drove it there was a slight vibration around those speeds if i remember right..but they are now gone.
I would say unbalanced tires or bent rims, BUT you mentioned it is only when you acelerated which eliminates those. Whether they are bad or not i do NOT know but I def say there is still something going on with the axels.
