93 integra b20b sputter problem
Old Sep 9, 2009 | 08:02 PM
i wouldnt ask me's Avatar
Default 93 integra b20b sputter problem
ok so i have a 1993 integra db1 automatic ,i recently put in a b20b in it and was running pretty good for a couple days but my engine light comes on so i pull the codes and its 13 and 41 which is atmospheric pressure(i dont know what that is please tell me )... and o2 sensor heater ...but i have another dilema my engine sometimes doesnt let me rev past 3400 rpm it just sputters until i let go of the gas. is this happening because of my codes? Please let me know its my dd and i need to fix it quick.
Old Sep 10, 2009 | 08:26 AM
Default Re: 93 integra b20b sputter problem
BUMP.. i need help
Old Sep 10, 2009 | 10:53 AM
ek-g6's Avatar
The sensor on the picture will need to be replaced or tested to make sure it works, its the one with the circle top hat.
As for the 02 sensor, i would try another known working 02 sensor, if not that ecu might be bad.
Old Sep 10, 2009 | 10:58 AM
keepinitrehaal's Avatar
My buddy had a DA and HE TOLD ME that when he had 2 codes, it would not let him rev past 3.5 either. Now i dont know if thats why its not letting you rev past that, thats just what he told me. So MAYBE when you fix the problems it will run normal. BTW what ecu are you running?
Old Sep 10, 2009 | 12:49 PM
thanks for the replys .i am running the stock b18a ecu .should i use a diffrent one
cpennington89
Feb 20, 2015 05:33 AM
papi123
Honda Civic (2001 - 2005)
Apr 25, 2014 09:07 PM
LudaChris
Oct 16, 2006 12:16 PM
H22aInside
Jul 31, 2003 03:59 PM
nautica_t
27
Oct 29, 2002 03:39 PM
