Z6 swap for a Y7...distributer question
Old Sep 9, 2009 | 07:51 PM
supercoy101's Avatar
Icon2 Z6 swap for a Y7...distributer question
im in the middle of a swap for my eg
my only question is pertaining to the distributer...
since my z6 is vtec and the y7 is not
do i need an obd1 non vtec distributer?
the y7 will be run with a p28 ecu
any help is apreciated.
Old Sep 9, 2009 | 08:51 PM
kiana60's Avatar
Default Re: Z6 swap for a Y7...distributer question
y7 does not fit z6, housing bolts dont match.
Old Sep 10, 2009 | 04:19 AM
94EG8's Avatar
Seagull Management
If i'm reading it right and its a Y7 going into an OBD1 chassis use a D15B7/D15B8 distributor.
Old Sep 10, 2009 | 05:15 AM
would a D16A6 distributor work as well?
Old Sep 10, 2009 | 08:40 AM
kiana60's Avatar
no, use the z6 housing and change everything over.
Old Sep 10, 2009 | 05:05 PM
94EG8's Avatar
Seagull Management
No.
No. The Z6 housing does not bolt up to a Y7 head. Use a D15B7/D15B8 distributor, bolts up and plugs in perfectly for this particular setup.
ef_hybrid
34
Jul 2, 2013 09:41 AM
greddytunedhatch
Feb 7, 2005 04:47 PM
SOHC_MShue
Oct 29, 2003 07:57 PM
ImportHatch
Oct 11, 2002 05:48 PM
