97 civic wont start. spark gas timing all good
Old Sep 9, 2009 | 07:33 PM
red-si-eg..'s Avatar
Default 97 civic wont start. spark gas timing all good
97 civic wont start it has spark gas and the timing is right. firing order good too. spark plug looks o.k. im thinking it might me the crank shaft position senor but there is no check engine light on. it was over heating the day before it started to acted up. i turn the crank pully and check to see if all the piston is moving and they all moved. its an automatic. i dont think its the headgasket because there no coolent in the oil.could it be the main relay or the ecu.
Old Sep 10, 2009 | 09:50 AM
hardeeboy's Avatar
Default Re: 97 civic wont start. spark gas timing all good
yea i had the same probalem with my 92 hatch and it was the main relay under the dash went to the local juck yard and bought like 3 so i could be sure also one of the fuses was bad under the hood it didnt show bad but it was .
Old Sep 10, 2009 | 10:00 AM
fireblaze2k1's Avatar
Does the starter turn over?
Old Sep 10, 2009 | 10:11 AM
Former User's Avatar
Originally Posted by red-si-eg..
97 civic wont start it has spark gas and the timing is right. firing order good too...but there is no check engine light on. it was over heating the day before it started to acted up.
What color is spark at the plugs?
If what you mention above is all correct, then compression test the cylinders.
Old Sep 10, 2009 | 10:21 AM
Unseen Racer's Avatar
do what ronj@ht said.
do a compression test. and if everything check out, do a
leakdown test
also check your main relay
Afi Salevao
Feb 1, 2014 10:29 AM
gowenburnett
May 30, 2011 05:20 PM
dashocker
Sep 1, 2008 03:26 PM
2ndGenREX
Feb 26, 2007 05:45 PM
speedlimitR
Jun 17, 2002 12:08 AM
