Benefits of ITR Rear LCA?
Old Aug 27, 2002 | 10:05 AM
fuguman's Avatar
New User
Default Benefits of ITR Rear LCA?
would i get anything out of getting the ITR rear Lower Control Arm?
i know the shocks are different (i would have to get the ones that fit itr)
would it improve handeling?
what are some other susp components that make the ITR handel better then non ITR tegs?
i know the subframe is a little diff and swaybar
Old Aug 27, 2002 | 10:48 AM
Civic1992DX's Avatar
Default Re: Benefits of ITR Rear LCA? (fuguman)
ITR has:
little stiffer unibody (with added braces & different rear subframe)
lighter weight
stiffer bushings material
LSD
I don't think ITR rear LCA will improve the handling.
Yuri K
Old Aug 27, 2002 | 10:52 AM
miketegra's Avatar
I think the only reason that people put the ITR rear LCA's on LS/GSR is because they are mounting ITR shocks (oem or aftermarket). I do recall reading somewhere that the ITR LCA's are beefier than the LS or GSR, but I'm not 100% sure.
I have a set of lightly used ITR LCA's and ITR shocks that will be going on my GSR one of these days - I'll be able to tell ya then if the ITR LCA's are beefier....
Old Aug 27, 2002 | 10:58 AM
Rory Breaker's Avatar
Default Re: Benefits of ITR Rear LCA? (miketegra)
The only benefit to rear ITR LCA's is the ability to run coilover setups like Tein HA's that arent available for regular Integras.
Unless you specifically want an ITR coilover system or have ITR shocks that you insist on using, its basically pointless.
Old Aug 27, 2002 | 02:04 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
They are much larger, stamped steel arms, and the shock fits through the control arm. The bushing is on the shock itself, with the bolt going through both the shock and the LCA. The non-ITR control is smaller, cast steel, with the bushing in the control arm itself. The shock has a fork that fits over/around the LCA, with the bolt going through both the shock and LCA.
jizzer671
Suspension & Brakes
Apr 2, 2007 01:04 PM
b18c4door
Jan 12, 2007 12:40 PM
da'ee
Jan 19, 2005 02:47 PM
P()()RB@Y
May 23, 2002 06:17 AM
