Help on 4x114 wheel bearing
Does anyone know what bearing would be used to replace a bad wheel bearing on a 4x114 hub. Would a gsr integra work? My wheel bearing just went out causing my caliper to hit my rf rotor. Pretty lame. If anyone know help me out
I believe a DC integra wheel bearing would work since the USDM ITR bearing is the same as the non ITR bearing - both of which have 32mm hubs and since the 96 spce ITR has a 32mm hub, and uses the same brakes as USDM non ITR, the bearings should be the same.
CTR-GSR
Jun 3, 2009 10:17 PM
wannabe_itr
Feb 8, 2009 09:06 PM
z6hatchboy
Feb 6, 2009 06:31 PM
pcorad
Nov 7, 2001 04:55 PM
