2000 hatch shift linkage problem
Old Sep 9, 2009 | 03:37 PM
sj-performance's Avatar
Default 2000 hatch shift linkage problem
I just threw a gsr swap into my 2000 ek hatch everthing is done except for the linkage.......... I put the linkage in but it seems to be to short....the stabalizer rod is fine and bolted up but the accual shifter is sitting to close to the dash looks like it is in first when in neutral works though just kinda anoying............ do I need a linkage from a 1999-2000 sir or si to you American fellas?????
Old Sep 10, 2009 | 10:48 AM
Default Re: 2000 hatch shift linkage problem
bump
Old Sep 10, 2009 | 11:36 AM
fireblaze2k1's Avatar
Yes you do. That is the proper set-up for your car. Also, check to see if you installed the shifter correctly. If it's backwards, it might cause the issue your talking about.
Old Sep 10, 2009 | 11:47 AM
90Rexx's Avatar
any B series linkage works, if your trying to reuse your stock linkage from your d series engine its wrong.
kp
Nov 30, 2011 06:37 AM
253kingpen
Northwest (Sales)
Jan 18, 2009 10:42 PM
wrx'n you
Feb 23, 2007 08:47 PM
boostng r
Dec 6, 2004 03:12 PM
6shootahorsenamedtrigga
Aug 31, 2004 12:31 PM
