High Idle & Check engine light
Hey everybody this is my first post. I have a 90' Acura Integra ls and I had the jumping idle. I just changed the tps sensor and when i started the car, the idle jumped up to 3,000 rpm and stayed there with the check engine light on. Then i messed with the idle sensor and now its down to 2,000 rpm w/ C/E light. I checked the ecu code and it blinked 7 times then stopped and then blinked 7 more times. so the code is 77. I googled the ecu code 77 and didn't find anything.
Can anyone help me?
Thanks!
Can anyone help me?
Thanks!
whats the icav? We got the idle down to 2,000. I tested out the map sensor from my friend's 92 gsr and it still does the same. So we ruled out that it wasn't the map sensor. We pulled out one of the vacuum hoses and the idle went down to normal but when he put the hose back on.... it jumps right back up. Could it be a vacuum hose? Today we're going to try a different throttle body.... that's the conclusion we came up with.
any other sugestions?
Iacv is the Idle Air Control Valve. its usually located behind the intake mani. its got two hoses plugged into it. one coolant and the other is a vacuum hose i believe.
Well the tps is fine now. Yeah the ecu code was 7 and all i had to do was move the tps sensor a little bit..... I'll check the iacv... any way to test if the iacv is still good or should i just replace?
greenzchatch
Jul 29, 2010 02:14 PM
Todd K
Jun 13, 2003 09:06 AM
