ASR Subframe Brace
i was wondering the same thing.. im sure someone knows... have you tried searching yet?? i haven"t searched yet i havent got that curious yet... imo if you got the asr subframe brace might as well get the upgraded sway while your at it.. ...
Take a look at this.
DC2 ASR SwayBar Reinforcement USDM ITR 22mm SwayBar
https://honda-tech.com/forums/acura-integra-6/dc2-asr-swaybar-reinforcement-usdm-22mm-swaybar-2256572/
the STOCK GSR sway bar will NOT work with the ASR brace, I've tried. The gsr sway bar is 14mm and 14mm is too small. the "D" brackets don't line up where they are suppose to.
everything is bolt on except you will have to drill out 2 holes to remove threads, and catch the additional thread plate included with the ASR subframe brace.
have fun with it
have fun with it
How did you bolt both braces up? I was thinking of doing this on my 93 GS but wasn't sure if it would work.
And to the OP, When I installed my ASR brace I checked to see if my ST rear sway would work and it wouldn't. I called ASR directly and the guy told me it was only designed to work with a type-R bar. Besides the ASR is Ubber nice. I would just upgrade, the only problem is finding a decent priced ASR bar.
dgdarien
10
Mar 30, 2003 01:09 PM
