stock rear motor mount 90 si how the fruck do i get that out?!!
it's nasty to get out you just have to work it.
if you are changing it I would cut it in half and just try to put new one in.
swivel socket with extensions.and lots of muscle
cut in half? man it aint that hard..theres only like 3 bolts u have to take off..the one in the rear..left side and front...and it slides right out..just use lots of muscle to loosen the bolts
i did mine about 3 weeks ago, and the back one is a pain the the *** to ge to, i used a swival socket and some other **** too. about 45 minutes later viola!~
regular socket and a ONE long extension....
Put the socket on the bolt head.... then stick the extension down by the firewall u may need to convince it with a hammer slightly
its cake when youve done it a million times
i guess it just require skillzzz and experience
lol, getting it out is easy, its getting it back in that takes a while, what I did was drop the rear crossmember/support and get back there with a long extension and a swivel socket, wasn't that hard, and when u drop the crossmember it gives u a bit more room
massage the firewall right where it bends towards the back of the car using a your extension & a hammer to make a crease right above the mount. Then, insert a socket (3/8" drive will do) with an extension down onto the bolt - this way, you can kinda see what you're doing - every car is a little different...it will save you time .
jthelman
Feb 29, 2004 05:35 PM
Texas Civic
Jan 13, 2004 01:57 PM
