forged or cast in ls vtec????(pistons)
Old Aug 27, 2002 | 09:12 AM
eddiecut's Avatar
Default forged or cast in ls vtec????(pistons)
i know that since there is not going to be oil squiters in my block that the forged would handle the heat better, but i have ctr pistons right now. the queston is, is it better to go with forged or cast?????
thanks for your opions in advace
justin
Old Aug 27, 2002 | 09:19 AM
sgT's Avatar
sgT
Default Re: forged or cast in ls vtec????(pistons) (eddiecut)
if you are using stock rods, they have holes to spray oil in the direction of the pistons
but i wouldnt worry too much either way
Old Aug 27, 2002 | 09:25 AM
eddiecut's Avatar
Default Re: forged or cast in ls vtec????(pistons) (sgT)
well stock rods on the ctr pistons but i would use eagle rods if i went with pistons like je, ross, or srd
Old Aug 27, 2002 | 09:30 AM
builthatch's Avatar
MiG-21 superfan
Piston material depends on your final setup goal. NA, you should be fine with cast. Their best asset is they are lightweight. If you are running rather high compression ratios, I'd do my best to keep the motor happy. Tune it properly (fuel+timing), cold plugs, run an oil cooler, lower temp thermostat, go over the cc and pistons and make sure there are no potential detonation inducing hotspots, make sure your clearances are perfect, etc. If you plan on boosting, no question, go with forged pieces.
[Modified by builthatch, 1:32 PM 8/27/2002]
Old Aug 27, 2002 | 09:37 AM
eddiecut's Avatar
Default Re: forged or cast in ls vtec????(pistons) (builthatch)
no its going to be all motor but its going to have rather high compression and i was just thinking i might as well put some good pistons in there becaue everthing else is rather nice
Old Aug 27, 2002 | 09:50 AM
builthatch's Avatar
MiG-21 superfan
Well, if budget is not an issue, I'd maybe consider some really high CR pistons that have been massaged to reduce detonation and allow you to run pump gas...Endyn for instance has some really nice wiseco offerings that allow you to do this.
Old Aug 27, 2002 | 01:23 PM
Turbo Laser's Avatar
The ls doesn't have oil squirters, forged internals resist heat better, and forged is better...if you have the cash. I'd get eagle rods and some type of forged pistons if I had the cash (or a car for that matter).
Old Aug 27, 2002 | 10:07 PM
eddiecut's Avatar
Default Re: forged or cast in ls vtec????(pistons) (Air Force 1)
thanks guys
killafred187
Oct 7, 2011 10:07 AM
queda
12
Nov 1, 2007 10:05 PM
PickleTeg
Apr 4, 2006 07:59 PM
blykins
Apr 8, 2003 10:41 AM
yisoulja
Jun 18, 2002 10:17 PM
