did a swap engine ticking
I swaped a y8 head for a z6head . started right up but there is a ticking noise for engine. I checked all values and adjusted but the ticking is still there. I tested drove to see if the ticking would stop ( when warmed up) still there. The engine also got hot but I think this is my fault do to I forgot to bleed radiator. So I will do that if not I have more of a problem. I hope this is helpful on info any help would be appreciated.
A spark arcing from the end of the spark plug wire to the top of the spark plug would make a ticking sound. You may need to pull the boot back so the end of the wire is long enough to clip onto the plug.
You're not using any non-oem (or oem-equivalent) ignition components are you?
As mentioned, check the ignition system. Is the engine oil low? Another possibility is a loud fuel injector. An inexpensive engine stethoscope might help you pinpoint the sound.
No I didnt the head came from machine shop had 300 miles put on it sat for about a month then I bought it from this guy put it on mine. So I amused they where good. But I also thought they would be adjusted right and they seemed a little off but like I said the ticking is still there.
So what you are saying is you did NOT adjust the valves yourself, you assumed they were good from the shop after sitting for a month? I would definitely cease operation of the motor and ensure the valves are at proper settings before driving around again.
Just so everyone knows, I just had leftover Steak and potatoes, and it was delicious... just a little FYI...
weaseloko
Sep 21, 2010 02:18 PM
sleepystyle
Sep 24, 2006 07:34 PM
chris408
Aug 10, 2003 07:37 PM
