Car wont start!!!!! Lots of info, need help
Old Sep 9, 2009 | 05:10 AM
milanoteg's Avatar
Default Car wont start!!!!! Lots of info, need help
Car: 98 Integra GSR
Motor will crank but won't turn over whatsoever.
info:
-Injectors have power going to them
-Spark plugs are new and work (they spark)
-Fuel pump works
-spark plug wires are new OEM wires, and work
-firing order is correct (used the diagram below)
-gas is full
-battery is good
-grounds are good
-connections are good and tight
diagram i used for firing order:
Old Sep 9, 2009 | 05:22 AM
mrdeadman's Avatar
They let me pick
Default Re: Car wont start!!!!! Lots of info, need help
Are you 100% positive you are getting fuel and spark?
Old Sep 9, 2009 | 06:22 AM
milanoteg's Avatar
Yes. I saw spark. and after cranking the spark plugs are wet with fuel. Also I pulled the fuel line (against the firewall) and cranked it for a sec and fuel came out. So definately getting fuel and spark.
I'm thinking there's got to be something wrong with the ECU but im pretty much stumped
Old Sep 9, 2009 | 06:23 AM
milanoteg's Avatar
I also tried some different firing order combos and the one in my first post is definately the correct one.
The only thing I did was install spark plug wires yesterday. And I just installed new plugs since I was in there, but they are gapped and installed correctly, etc.
Old Sep 9, 2009 | 06:54 AM
mrharmonic's Avatar
try the tdc. " top dead center" that whould be the best part to sart over did that to my gsr and it works it strated right up, but had to go get the timeing re done but it worked.or get a new p72
Old Sep 9, 2009 | 07:01 AM
milanoteg's Avatar
update, there's no spark anymore. Cant be 100% sure if there was spark to begin with, my dad was the one looking for it he said he saw it (he is a licensed mechanic)
Old Sep 9, 2009 | 07:30 AM
Zappythebum's Avatar
no spark = bad wires? you should re-use the old wires that were working before (i assume they were working), since you said you replaced the wires maybe they could be faulty and you bought the unlucky box of wires
Old Sep 9, 2009 | 07:33 AM
milanoteg's Avatar
Yup already tried that. Old wires don't work either. Yesterday everything started up fine. It's just today giving me problems.
I'm completely stumped. My friend said something about the dizzy connections being burnt out but at this point I'm about ready to bite the bullet and tow it to a local acura stealership to see if they can diagnose it.
Old Sep 9, 2009 | 07:40 AM
96lsvtec-t's Avatar
check your rotor and cap.... if they are okay, pull the ICM and check it out.
Old Sep 9, 2009 | 07:53 AM
milanoteg's Avatar
Rotor and cap look fine. What should i be looking for on the ICM?
Old Sep 9, 2009 | 07:58 AM
milanoteg's Avatar
Hmm what if I blew the ICM, it's basically a fuse, right?
Some more info i forgot to mention yesterday I painted my valve cover, everything was reinstalled correctly but I forgot to connect the engine ground. I rode around for a little bit without it connected (1 hour's worth of driving i'd guess). It was acting weird, bogging down, weird A/F it seemed, even stalled out once.
So maybe having the ground disconnected for a short period has something to do with it?
Old Sep 9, 2009 | 08:14 AM
follie gatts's Avatar
bad grounds usually just cause fuses to blow, so if what you say about the ICM is true then that may be the problem.
Old Sep 9, 2009 | 08:16 AM
milanoteg's Avatar
Here's where I read about ICM's http://www.team-integra.net/forum/di...g+Common+Topic
some good info in there.
something in the dizzy would definately explain why there is no spark, but would it explain why I had problems driving it last night? Started up fine, but would bog down under low RPMs and even stalled. The fact that the car was running means the dizzy was working, right? that's the thing that's confusing me.
Old Sep 9, 2009 | 08:31 AM
obeyphysics's Avatar
My car did the same thing you described. It was driving fine and the next morning it wouldn't crank at all. I replaced everything you mentioned, (plugs, wires, fuel pump, fuel filter, cap, rotor, checked the injectors for flow, checked fuel pressure, carb cleaned the TB) and it still wouldn't turn over but it would crank. I checked the plugs for spark, cause the week before I noticed super bad gas mileage and tried one last thing, the ignitor in the dizzy. Well that didn't do it so I had the car towed to the shop that helps me out and not an hour later the owner called and said it was the dizzy. He took it apart, put everything back together and it was gravy. Haven't had a problem since.
Old Sep 9, 2009 | 08:53 AM
milanoteg's Avatar
so you suggest I take it apart and put it back together?
Might as well if I'm going to end up towing it...
Old Sep 9, 2009 | 09:06 AM
white_gsr's Avatar
x2 agreed! samething happened to my old 95 gsr.
Old Sep 9, 2009 | 09:13 AM
milanoteg's Avatar
well it looks like im not going anywhere else today, so out comes the dizzy
Old Sep 9, 2009 | 10:13 AM
Yes, haha I do suggest that you take er apart and try and reassemble it. It should take you ~2 hours ish. My "mechanic" tech buddy did mine in just over an hour.
Old Sep 9, 2009 | 11:01 AM
milanoteg's Avatar
I just got my buddy to pull me to a local shop. They know me there so they're going to take a look at it and let me know whats up.
I'll update this thread as i recieve more info in case anyone else is having similar problems.
Old Sep 9, 2009 | 11:21 AM
wunfstgsr's Avatar
Loved
Community Favorite
I bet oil seeped into the dizzy or a bad coil in the dizzy!
Old Sep 9, 2009 | 09:28 PM
gokooljapan's Avatar
either bad iginitor or coil is burnt. Once the coil is removed, you can tell if the coil is burnt by a little burn mark on the front corner of the coil. You can't miss it.
Old Sep 9, 2009 | 09:55 PM
Oreo-TeCk's Avatar
bad ecu
Old Sep 10, 2009 | 03:43 AM
TekBuDDy's Avatar
you probably have a bad ign coil.
Old Sep 10, 2009 | 07:06 PM
milanoteg's Avatar
Lots of you got it right. It was the ignition coil.
Got absolutely raped on price by the shop, but it's all fixed now, and next time if it ever happens I know exactly what it is. I also know the internal workings of the dizzy. Learned a lot from this mis hap.
Thanks guys
Old Sep 11, 2009 | 09:39 PM
wunfstgsr's Avatar
Loved
Community Favorite
ha ha!
