please someone help me :(
How do you know you have spark issues and not fuel problems?
First check and make sure you have battery power near 12 or 13 volts.
second (since fuses have been checked) pull a spark plug wire put a spark plug in the loose end have someone try to start the car and look for spark at the plug tip. If no spark that points to the distributor or a part inside (ignitor, rotor, ect..). This is pretty common. Did you also check the ignition fuse under the hood?
GL
GL
keithv
10
Mar 6, 2003 06:28 PM
