ecu code #20
what does the E.L.D - electric load detector mean. Ive heard it means that the circuit is unplugged or needss to be cleaned. But what else could it possibly mean?. And The fuel pump is not properly working.
fuel pump may be main relay related. do you hear the relay click on and off when you turn the key to run?
the eld may be toast, or it may be as simple as a loose ground wire.
test 'er out
test 'er out
actually i dont hear anything click except a buzz to it thats it but yea thanks for the info
also i know my eld fuse circut is good because i swapped it with my brother's on his ef and it worked in his car so its got to be something else like maybe a ground wire does anyone one know were all the stock ground wires are suppoed to be in an ef chassis
I had that happen once because I did a bad mpfi swap at the ecu. I had accidentally mispinned one wire to pin b8 instead of b10 or something like that. If I were in your place, I would check to see if you have a loose wire at the ECU.
you know what yeah maybe thats what it is thankx ill check that
raverx3m
Sep 16, 2011 11:09 PM
B18 CYA
15
Sep 16, 2006 12:04 PM
turbocivic96
Mar 15, 2004 12:35 PM
