Exedy Clutch/Clutch master cylinder and pushrod assy. question and request.
Old Aug 27, 2002 | 08:21 AM
mstewar's Avatar
Default Exedy Clutch/Clutch master cylinder and pushrod assy. question and request.
Ok, well, I got my Exedy organic clutch and Comptech flywheel in, but now I've run into an interesting problem. Since there's a bulletin out on the clutch, I went to do the required adjustment, but it appears that my pushrod assembly is different from OEM(if not the master cylinder and everything).. Instead of having a locking nut and a nut with a boot on it to adjust, i have a locking nut and some sort of bell thing on the rod, which doesn't appear to be able to be adjusted independantly.. fortunately, the car is driveable, i just have to shift with the pedal only 3/4 down..
if possible, can someone post the exploded diagram out of the helms, or off acura's part's computer that show's this assembly? i especially need a view of the pushrod, but the whole master cylinder assy. would be a great help..
and my questions - can I just replace the pushrod with an OEM one, or does the whole master cylinder need to be replaced along with it? or is this a pedal issue?
**INTERESTING NOTE: I talked to exedy about this, and people with this clutch are familiar with the adjustment that is needed to be performed in order to be able to shift with the pedal at the floor, but everyone will probably find this amusing. The guy at exedy/daiken suggested that I either a)possibly replace the assembly, or b) place a block of wood, secured with duct tape, on the floor so the pedal stops earlier. Yes. He really said that. I'll be sure to call them with any more technical questions I have.
Old Aug 27, 2002 | 08:51 AM
sgT's Avatar
sgT
Default Re: Exedy Clutch/Clutch master cylinder and pushrod assy. question and request. (mstewar)
loosen the locking nut and turn the rod. very simple
Old Aug 27, 2002 | 09:05 AM
Willard's Avatar
the bell 'thing' has the other nut just inside it. use a thin headed 12mm wrench to hold the nut that is mounted to the bell 'thing' and use another 12mm wrench to loosen the lock nut.
[sp]
[Modified by Willard, 1:05 PM 8/27/2002]
Old Aug 27, 2002 | 09:12 AM
Johnny Tran's Avatar
Default Re: Exedy Clutch/Clutch master cylinder and pushrod assy. question and request. (Willard)
i vote for a block of wood and duct tape....
tran, who doesnt work for exedy.....but thinks they sound c00l
Old Aug 27, 2002 | 09:31 AM
mstewar's Avatar
ok, so I DO have the original assembly then, it sounds like? i guess I'm just losing my mind or something..
is the rod supposed to move independantly of the "bell thing"(as i call it.. hehe..), once the locking nut is loosened?
sheesh.. i read all the stuff I found in search about this and still am not getting it.. hehe.. for me..
Old Aug 27, 2002 | 09:42 AM
Willard's Avatar
yes... it will twist and thread in and out of the bell to gain the desired length... once the noise goes away.. lock the nut back and hit the road.
gooblinn258
Jan 18, 2014 05:02 PM
ohsnapzafingcu
May 16, 2011 04:30 PM
nothome17
Acura TSX
Sep 30, 2010 11:06 AM
FuNkDrSpOt
Oct 10, 2006 09:48 PM
jdmcivicferio
Apr 9, 2004 09:44 PM
