FS: B16B TypeR swap Complete
Sup guys. Im finally parting ways with my beloved B16b swap. This thing is a super strong Motor and i really hate to part with it but i want to go K. That said. i would take a trade on a k series motor or something along those lines. i need everything gone out of the car so it would come with pretty much everything you will need to do the swap into a eg including Hasport linkage, BRAND NEW axles, Skunk2 ecu, Hasport mounts, Wiring harness. setup as follows
Engine:
Stock B16B block & Head
Arp Headstuds
Buddy Club 2 Layer HG
Profab Plastic intake mani gasket
OEM ITR header, Intake mani and injectors
Gsr Throttle body.
3 Inch intake
NGK plugs and wires
New OEM Honda Oil pump, Water pump, Timing belt, oil pan gasket, Cam seals and valve cover gasket kit.
Trans:
JDM ITR 98+ spec
Quaife LSD
4.789 Final drive
Gear speed Carbon coated Syncros 2-4
Exedy stage 1 clutch
ACT Prolite flywheel
Skunk2 Chipped p28
Hasport Billet mounts EG/DC
Autozone axles
Price: 3200 OBO trade for a kswap or something like that :-) more pics just ask
Engine:
Arp Headstuds
Gsr Throttle body.
3 Inch intake
NGK plugs and wires
Trans:
JDM ITR 98+ spec
Quaife LSD
4.789 Final drive
Skunk2 Chipped p28
Autozone axles
hi there im in the uk and i am thinking of doing this conversion would you recommend doing it. and do you have any links that can show me how to do the conversion as i am wanting to use everything from a ek9 apart from the gearbox i have the obdo-obd2a ecu harness. kind regards
Tb0y
Jun 13, 2015 04:50 PM
bump
