vtec does not come on
Old Sep 8, 2009 | 04:56 PM
the_dxB16's Avatar
Default vtec does not come on
i had a b16 i think obd-1 but i got a b16a2 head and everything is connected no check lights are on. My vtec is not coming on. why is that?
Old Sep 8, 2009 | 04:57 PM
Arthas's Avatar
Default Re: vtec does not come on
Dont try and be so specific next time.
Old Sep 8, 2009 | 05:02 PM
the_dxB16's Avatar
lol what do u mean dont try??
Old Sep 8, 2009 | 05:03 PM
ej93's Avatar
did u jump the ecu to make sure
Old Sep 8, 2009 | 05:06 PM
the_dxB16's Avatar
is that when i connect the two pins and turn the car on?
Old Sep 8, 2009 | 05:08 PM
roadsqueegy95's Avatar
yes
stupid question...but did u check your oil level?
Old Sep 8, 2009 | 05:13 PM
the_dxB16's Avatar
i didnt check the oil level why should i check it
Old Sep 8, 2009 | 05:18 PM
Kista20's Avatar
because vtec needs oil pressure for it to work, also do you have any cel's? if your cel is on that will prevent vtec as well.
Old Sep 8, 2009 | 05:26 PM
the_dxB16's Avatar
no cel's but ima jump the ecu then try it.
Old Sep 8, 2009 | 06:05 PM
Jimster480's Avatar
you need to flip the VTEC switch for it to come on. Your VTEC switch must be in the off position.
Old Sep 8, 2009 | 06:14 PM
Arthas's Avatar
A lot of people here want to help you out but be more specific when you need something trouble shooted.
You dont just tell your doctor that somethings wrong with you and expect him to magically know whats up with you without knowing details.
Old Sep 8, 2009 | 06:50 PM
check oil level yet? u need oil to get the MaD VTECH yooo!
Old Sep 8, 2009 | 07:16 PM
JDMH22HondaPrelude's Avatar
check pin goin to ecu. may not be connected well enough. had that problem with a prelude once.
Old Sep 8, 2009 | 07:27 PM
tsikot93's Avatar
what kind of vehicle are we talking about? is this a swapped motor? do u a the proper ecu? if your vtec is inop. it should give you a dtc code (check engine light)
Old Sep 8, 2009 | 08:03 PM
Jimster480's Avatar
I'm still sayin he needs to flip the VTEC Switch.
Old Sep 8, 2009 | 08:08 PM
tsikot93's Avatar
just jump the vtec connector
Old Sep 8, 2009 | 09:30 PM
the_dxB16's Avatar
I have a 93 civic coupe b16 swap p28 ecu. The oil is fine and i jumped the ecu still nothing. The only cel its giving me is TDC sensor 8 code. the vtec was working with my old head. should i try my old vtec?
Old Sep 8, 2009 | 10:47 PM
the_dxB16's Avatar
bump!
Old Sep 8, 2009 | 11:22 PM
goldfinger93030's Avatar
X2 thats the first thing you learn have to do when you get a honda!
Im pretty sure a TDC cell would keep you from being able to hit vtec
Old Sep 9, 2009 | 11:14 AM
the_dxB16's Avatar
yeah i switched it on and i beat lambo lol
well that code has been on for couple of months im going to take it to the dealer. im tired of that light lol.
Old Sep 9, 2009 | 11:22 AM
tampabud's Avatar
Is the timing good? TDC stands for top dead center... if that sensor is going off, maybe your timing is bad? Where is RonJ?? He could answer this with a quickness. Cheers!!
Old Sep 9, 2009 | 03:33 PM
Jimster480's Avatar
ya today I raced a new Si in my Built Turbo D. I thought he might win so i turned on VTEC and I raped him by 3 cars.
(real race & results, fake VTEC story).
Old Sep 9, 2009 | 04:12 PM
tsikot93's Avatar
do u know that the tdc is part of the distributor on obd0, right?
Old Sep 9, 2009 | 06:35 PM
Jimster480's Avatar
wat does the OP's problem have to do with OBD0? He doesnt have OBD0.
Old Sep 10, 2009 | 10:52 AM
the_dxB16's Avatar
ok im going to re-check my timing. do the "up" on the sprockets exactly 90 degrees from the cam sprockets?? or the floor?
