2004 Civic EX Tranny
Hey, i have a automatic 04 Civic and was wanting to convert it to a 5-speed. Well i'm looking for the whole transmission to do the conversion. Parts i would need would be:
Manual Transmission
Manual Subframe
Front Manual Motor Mounts/Transmission Mounts
Shift Linkage
Shifter Assembly
Pedal Assembly
Slave Cylinder
Master Cylinder
Manual Axles
Clutch, FlyWheel, Pressure Plate
Manual Transmission Fluid
And i dont NEED these but if you have them on hand i would gladly take them!
Manual ECU
Manual Engine Harness
Manual Dash Harness
Manual Center Console Trim Bezel
Manual Cluster
Hopefully someone can help me out here and if you dont have it, but know someone or some website that does, just point me in the right direction..thanks!
Manual Transmission
Manual Subframe
Shift Linkage
Shifter Assembly
Pedal Assembly
Slave Cylinder
Master Cylinder
Manual Axles
Manual ECU
Manual Dash Harness
Manual Cluster
BigPlansNoMoney
Dec 29, 2004 12:53 PM
