b16 ticking??knock?? help
Old Sep 8, 2009 | 04:19 PM
jdmstyleg's Avatar
Default b16 ticking??knock?? help
ok so heres the story
motor has a funny idle, sometimes stays right at 100rpm other times casually drops as if it wants to shut off.
when its at 1000rpm it has a slight ticking noise and it sounds as if it comes from the block,
when it starts to wanna shut off it gets louder.
but then as soon as the car is around 1500+rpm the noise vanishes?
help??
Old Sep 8, 2009 | 04:25 PM
ej93's Avatar
Default Re: b16 ticking??knock?? help
i had that same problem......and it was that i had spun a rod bearing but a could be wrong. hopefully that helps
Old Sep 8, 2009 | 04:30 PM
jdmstyleg's Avatar
its just such a quiet noise that it dosent sound like a KNOCK just like a small tap
did you end up replacing the bearing or no?
d155spd
11
Jul 14, 2018 10:04 AM
Przekop20
Feb 26, 2014 07:03 PM
Touge Tuning
Jul 4, 2006 09:13 AM
sleeperek
Feb 2, 2004 06:05 PM
DeDonDeRosa
Aug 1, 2002 08:20 PM
