fog lights arent working 94 civic hatch
Old Sep 8, 2009 | 10:22 AM
JMaldo87's Avatar
Default fog lights arent working 94 civic hatch
i replaced the light bulb for my 94 civic hatch foglights and when i turn them on they blow the fuses. it had a 30 amp fuse it in originally so i put in a 40 amp fuse in. Now all the wires some and melt whenever i turn them on. i dont know if its because im grounding out or the fuse is to much amps. any advise??
thanls
Old Sep 8, 2009 | 10:33 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: fog lights arent working 94 civic hatch
dude. make sure the ground is grounded properly
but this seems to be your problem. your power wire is touching ground. that will blow anyfuse and or start fires......................................
Old Sep 8, 2009 | 10:40 AM
PhatFactory's Avatar
yea, double check all your wires for the foglite. It seems like there's a loose wire or broken wired somewhere, it's might be grounding out. Good luck.
Old Sep 8, 2009 | 05:07 PM
EJ8-Yao's Avatar
Yes sirr..I had that problem also..every time i put on a new fuse and turned it on..It' blow. So i took everything out and re checked all my wires and a little part of my ground wire was loose and it was touching i think my bumper frame which was metal..so I just taped it up with electrical tape and that fixed that..hope you get it.
Old Sep 8, 2009 | 07:05 PM
durfeec's Avatar
just had the same problem a couple days ago. they were cheap eBay ones. make sure you actually take the light apart where the wires go into the light and check those wires too.
Old Sep 8, 2009 | 07:23 PM
green99civic's Avatar
After market fogs are very picky for some reason you have to make sure you have a very strong power and strong ground or they just wont work.
Old Sep 10, 2009 | 02:49 PM
JDM_CIVIC_EJ8's Avatar
hey i got a quick question my buddy and i put a pair of foggies on my 00 coupe and we had problems after we got everything put in but we figured out the problem we were grounding the power wire and we fixed that then the next day they stopped working again and we had found water in the orange and blue connector that connects to another wire and is covered by a clear i wanna say but connector, so then the relay stopped clicking so i ordered another relay from the company i bought them from and put it in yesterday and still no luck any one have any ideas as to why its still not working? thanks
Steven P
May 7, 2016 02:36 AM
trackDC
Oct 8, 2014 06:06 AM
barone
Jun 4, 2011 07:21 AM
OneFire
Audio / Security / Video
Apr 22, 2009 02:07 PM
Hatch It
Apr 13, 2004 03:31 PM
