Transmission & Drivetrain Gearboxes, Differentials, Clutches
ls gearset on gsr shafts?
Old Sep 8, 2009 | 03:51 AM
cousin_ed's Avatar
Default ls gearset on gsr shafts?
hey guys. i have a blown 95 gsr trans (chewed syncros and hubs) and a good cable ls (think its a 92).
my car is a 92 hatch so its hydro. can i put the good cable gearset on the gsr's main and countershaft?
so itd be like a gsr FD with LS 1-5. still be hydro.
that work???
hell the gsr gears are good. could i use the ls syncros and hubs on the gsr gearset???
Old Sep 8, 2009 | 07:36 AM
Honda Bull's Avatar
Default Re: ls gearset on gsr shafts?
If it is a 92 trans, then yes, the gears are compatible on the shaft. You'll only really be changing 3-5 though, as the GSR 1-2 are the same as the LS. Also, the LS synchro hubs/sleeves/synchros don't fit the GSR gears for 2/3/4. Can't remember for 5/R.
Old Sep 8, 2009 | 01:44 PM
cousin_ed's Avatar
so i can put the entire cable ls gearset on the gsr shafts inside my gsr hydro case?
Old Sep 8, 2009 | 02:36 PM
Honda Bull's Avatar
Provided that you have the 92-93 'big spline' LS trans, yes.
Old Sep 12, 2009 | 08:50 PM
night's Avatar
a 92-3 cable is the same as the hydro.
if it was a 90-1 it would look significantly different.
.all-motor+.eG8
Feb 23, 2012 03:33 AM
Skunk U
Jun 21, 2010 03:32 AM
DA9Rood
Sep 23, 2006 01:38 PM
mitsuman
Nov 14, 2002 01:44 PM
