P30 or Chipped P28 In B16a 93 EJ1
hey heres my current setup.
JDM B16a swap
y21 tranny with LSD
AEM Ram intake
Stage 2 Clutch
lightweight Flywheel
ebay short throw shifter
2.5 exhaust tubing with cat and resonator
apexi muffler
cx racing dual core radiator
what ecu should i be running? what are the pros and cons of each. the p28 ecu was chipped by speed innovations and the p30 is not chipped.
i plan on buying this winter. def dont drive in snow
skunk2 stage 2 cams
megan 4-2-1 header
if i can afford
skunk2 intake man
throttle body
aem fuel rail
JDM B16a swap
y21 tranny with LSD
AEM Ram intake
Stage 2 Clutch
apexi muffler
skunk2 stage 2 cams
megan 4-2-1 header
if i can afford
skunk2 intake man
throttle body
aem fuel rail
So you already have a chipped P28? I would just run the Chipped P28 and get it tuned if you havent gotten it tuned already. Just make sure its chipped to run a B series, since a P28 is for a D series originally.
well i put the chipped p28 in last night and drove around today. it def runs in my engine. engine runs the same as the p30 that was in previously so i take it it is chipped for a b16a. also when i installed the p28 my cel went off. what could cause this???? all i really noticed was my vtec kicks in at around 4500 instead of 5500. but when it does kick on earlier it seems like its not as strong as when it was at 5500. at 5500 when it kicked on it was considerably louder than before vtec hit. i know that at higher rpm it is louder but its only 1000 and its quite a difference in tone when the vtec kicks in. is this normal.
