Rear disc brake conversion help.
Old Sep 7, 2009 | 06:09 PM
Ek9andyroo's Avatar
Default Rear disc brake conversion help.
I have a 2000 dx civic hatchback (non-abs). I want to do a rear disc brake conversion with the brakes from a 99-2000 civic si. What exactly do I need to change, and what can I keep from my car?....ebrake cable, master cylinder, brake booster,...etc.
Any help is appreciated. Thanks.
Old Sep 7, 2009 | 06:14 PM
Arthas's Avatar
Default Re: Rear disc brake conversion help.
I did a DA rear disc conversion and I kept my Master cylinder and brake booster if that helps.
You need to change the trailing arms and run the eBrake cables to the eBrake.
Old Sep 8, 2009 | 08:38 AM
Ek9andyroo's Avatar
did you have to get new ebrake cables? or were you abel to use the stock cables?
Old Sep 8, 2009 | 09:28 AM
Arthas's Avatar
I used the stock eBrake cables from the DA. They fit perfect on my friends EK sedan, but on mine it feels as if they dont grab the e Brake hard enough, and I have to pull up all the way for it to work.
Old Sep 8, 2009 | 09:35 PM
ImportHatch's Avatar
Did you adjust it?
Old Sep 9, 2009 | 12:05 AM
Arthas's Avatar
Yeah, but it didnt do ****.
Old Sep 9, 2009 | 12:42 AM
Group Tenacity's Avatar
I think u also need the proportioning(sp) valve.
I helped my friend do a rear disk conversion on his hatch, we used the e brake cables that came with the new trailing arms. we also used SS brake lines for the integra that the trailing arms came from.
CrAzE191st
Aug 30, 2010 05:31 AM
asianman139608
Oct 26, 2009 07:21 AM
Romo Pyro
17
May 8, 2009 10:04 AM
Excelerate
Mar 22, 2004 01:42 PM
Ya@inlinePRO
Mar 14, 2002 11:41 AM
