4th Gen Sleeper project
Old Sep 7, 2009 | 03:46 PM
airhonda92's Avatar
Icon2 4th Gen Sleeper project
Hey guys, new to the site and am looking for tips, trick etc... I have embarked on a 92' accord sleeper project. Goals are to hit the 300+ HP mark with the F22 block and head. I've thought about using the H23 head but haven't decided. I have done a lot of research on this project and it sounds to me with new internals, rebuilt head, and 10#s of boost I should be able to reach it. Currently have an F22A1 block at my machinist shop being bored .020 over. Will be looking to do a rotating assembly, I am having trouble finding one as a kit. From the looks of things I will have to piece it together. Since the block is steel sleeved already I'm not concerned about sleeving it. I am looking at doing Wiseco pistons, K1 rods and I haven't been able to find a crank. Honda-performance.com has some decent looking kits but I don't know anyone that has used them. I will be using their girdle kit to help close the deck. Looks like a couple guys on here have a boosted SOHC 16v F22s, very good to see! Any tips or advice would be very much appritiated! Thanks.
Old Sep 7, 2009 | 06:10 PM
sickdime's Avatar
Default Re: 4th Gen Sleeper project
if the crank ain,t hurt don't screw with it. honda cranks are stong and 300hp won't kill it. rod and piston are enuff . get it balanced and lose the counter balance shafts. 300hp is going to require some boost. invest in the good stuff , beware of the EBAY junk. and o yeah GOOD LUCK
Old Sep 7, 2009 | 09:51 PM
jhondayang's Avatar
u can easilyy go with the dsm turbo and manifold set up. possibly a dsm manifold and a 16g turbo.
Old Sep 7, 2009 | 10:05 PM
airhonda92's Avatar
The main reason I was looking into replacing the crank was because of the 200k+ on it... Wasn't sure if it would last under that much horse... Also I had heard the DSM stuff would bolt with a little modding... Haven't made it that far though. I want to get the motor done by November and once it's ready I will know exactly what I'll want for a turbo set up... Also trying to avoid dropping $10k into it! Ha! Thanks guys!
Old Sep 8, 2009 | 09:33 AM
97cl2.2's Avatar
good luck my f22b1 has 92k on it now and its auto. i wish it was stick so id want to swap it or boost. now i have to pay for the manual swap which is more..lame. boosted f22's are sick again good luck
Old Sep 8, 2009 | 01:15 PM
Brad_and_the_acc's Avatar
300hp has been done on boosted F`s.. There are a few members here that can vouch for that much power on the F block.. What about the head? I seen you mention the short block at the shop.. The stock F Sleeves are good for 300+.. What pistons an rods? What kind of compresion are you thinking?
Maybe I missed it but I though that the DSM setup was for F22Ax?? I could be wrong I thought the pattern was 0-0-0-0 for the DSM. The F22Bx has 0-00-0 exhaust port pattern.. Anyway, in for more on this as it happens..
BTW, I am F22B2 Boosted @ 8lbs daily an love it.
GL.
Old Sep 8, 2009 | 10:34 PM
airhonda92's Avatar
Icon6 Re: 4th Gen Sleeper project
The head will be port pollished, camed, over size valves and springs. I will have my machine shop do all that as well. As for pistons I'm going .020 over by recomendation and am havin some trouble finding them. Originally I was going with wiseco but they don't seem to have what I'm looking for. Now it's probably going to be JE or SRP. I'm looking at probably 8.5-1 or 9.1 compression. Rods I found with K1 H beam, they sound reputable. I've had other members tell me to stick with the stock crank, your thoughts? As far as DSM, I am doing an F22A1 so I think that is still an option, however at this poi t I just want to get my motor complete lol. What's the mm diameter of .020 over from standard? Is it 84mm? I don't know for sure. Anyway thanks for all the support, I don't have anyone up here so this has been very useful!!
Radyjr
Jan 12, 2010 03:55 PM
nobe
Nov 4, 2006 10:49 AM
civic_mattattack519
Aug 31, 2006 03:08 PM
kidrolla
Oct 17, 2005 03:54 PM
ChaosUnbound
Dec 25, 2004 08:35 PM
