gsr in del sol, axles aren't long enough
Old Sep 7, 2009 | 01:10 PM
91(si)hatchey's Avatar
Default gsr in del sol, axles aren't long enough
hey i have a gsr in my del sol. the motor sits fine and everything but the axles are stretching(the boot distorts u could say). im using brand new 95 integra axles and intermediate shaft.
Old Sep 7, 2009 | 01:56 PM
90Rexx's Avatar
Default Re: gsr in del sol, axles aren't long enough
pictures or no one can help you....
sounds like you dont have integra axles...
Old Sep 7, 2009 | 06:37 PM
so i had rs axles and they weren't long enough, i exchanged them for gsr and now everythings fine
Old Sep 7, 2009 | 07:00 PM
bar'dh22's Avatar
there both the same length
Old Sep 7, 2009 | 09:33 PM
u would think. autozone has like a few different brand axles. all of them but 1 had identical part numbers as the gsr. well the one they gave me was that 1 that was different. the gsr axles i got fit just fine
Old Sep 7, 2009 | 10:05 PM
bar'dh22's Avatar
the part numbers are diff because of abs otherwise there the same length
Old Sep 9, 2009 | 04:52 PM
well they didn't work so there was something going on, and no its not my car or the installation
Old Sep 9, 2009 | 04:55 PM
forcefedferio's Avatar
did you try to "burp" the boot? sometimes new CV axles are like that. Just wedge a screw driver under one end of each boot and it should allow an air pocket to escape and the axle should be long enough then.
or they gave you the wrong axles. but try to burp them first.
Old Sep 9, 2009 | 06:54 PM
thumper64's Avatar
The only difference between the RS and GSR axles is that the GSR has a collar around the outside that works in conjunction with a sensor on the knuckle for the ABS system.
Old Sep 10, 2009 | 06:52 AM
SPOOLINmatt's Avatar
yep same length, you had a jacked up axle.
DelSolMarine
Apr 26, 2006 04:42 PM
DelSolMarine
Apr 12, 2006 08:39 PM
TylerC
Nov 7, 2005 07:06 PM
jerbear!
Nov 15, 2004 10:58 AM
