On the side of the road with my iPhone! Help. Car won't start
Old Sep 7, 2009 | 12:38 AM
Mrmatt3465's Avatar
Default On the side of the road with my iPhone! Help. Car won't start
Ok so I'm on my way home. A pleasant 3 hour drive halfway through it and I hit a large unavoidable bump. My car shuts off and everything twaks out. Gauge cluster gets power and signal on and off, clock is flickering, motor won't push start or crank start.
Here's the freaky part. I put the key in and go one click forward, radio comes on fine. One more click forward, empty. No main relay kicking, no power to gauge cluster and no power to fuel pump or anything besides radio. Crank click forward and main relay kicks and motor starts but dies as soon as I let go of the key.
93 civic hatchback with an ls swap. Perfectly running and healthy.
I've checked grounds and fuses. Grounds are secure, both of them, and fuses are fine. I've checked all connections for sensors on the motor, secure.
Can somebody please help me get home?
Old Sep 7, 2009 | 12:44 AM
Eran's Avatar
HT White Ops
Default Re: On the side of the road with my iPhone! Help. Car won't start
Sounds like your battery is toast. If your battery is fine, then it's probably your knock sensor plug.
Guess they don't make an app for that.
Old Sep 7, 2009 | 12:48 AM
Mrmatt3465's Avatar
I'm pretty sure it's not my battery asni get power. And everything cranksni just can't keep the motor running ecause there is an electrical issue somewhere. I need ideas on possible electrical issue that wouldcause an issue like this.
Old Sep 7, 2009 | 01:28 AM
Mangotreemechanic's Avatar
When the engine cranks but won't stay running, does the instrument panel and warning lights go dark?
Try turning the key to start position, and when the engine begins to start, let the key come back to the "running/on" position while still holding the key. Does the engine continue to run?
If so, then the ignition switch has bad contact points. There is a DIY home repair, or you can get a new one for replacement. You will have to check in this forum for repair or replacement steps.
Check with the above tests first.
Old Sep 7, 2009 | 02:54 AM
fastrxu's Avatar
knock sensor has nothing to do with it
is it 5speed? pushstarting it?
Old Sep 7, 2009 | 08:00 AM
Former User's Avatar
Fuses 15 and 24 under the dash may be blown.
Otherwise, check the ignition switch.
Old Sep 7, 2009 | 08:40 AM
brutekiller787's Avatar
maybe the fuel pump fuse because he says it cranks but won't keep going. to me that is a fuel delivery issue
Old Sep 7, 2009 | 10:34 AM
Eran's Avatar
HT White Ops
When we were putting together my friend's LS, if the knock sensor wasn't plugged in, it wouldn't start.
Old Sep 7, 2009 | 12:33 PM
Mrmatt3465's Avatar
Thanks a lot for your help guys. I have a bad ignition switch. I got it towed home last night. A pleasant 100 mile tow.
Old Sep 7, 2009 | 06:12 PM
Arthas's Avatar
I bet that cost you a pretty penny.
Old Sep 7, 2009 | 06:20 PM
!IShockedURMom!'s Avatar
ouchh
Old Sep 12, 2009 | 10:47 AM
You're welcome. Glad to help.
2LGSR
23
Apr 22, 2010 07:40 AM
Fresh Ej2
26
Apr 2, 2009 06:19 PM
kreeper
Feb 17, 2009 11:10 AM
drshottest718
Mar 26, 2007 03:47 PM
deftones0817
Jul 14, 2005 08:17 AM
