Cigarette lighter Mod
Old Sep 6, 2009 | 11:57 PM
jin4g63's Avatar
Default Cigarette lighter Mod
I'm planning to store my car for about a year so i was trying to hook up the Coleman Solar Powered Trickle Charger so i can save my battary from dying but i believe my 94 accord does not have any power going to the cig lighter when the ignition is on off position so im asking if there is a way to have constant electrcity going into the lighter i dont know anything about electrical so help me out thank you.
Old Sep 7, 2009 | 07:59 AM
fcm's Avatar
fcm
Old Fart
Default Re: Cigarette lighter Mod
If you are going to store it for a year why not just disconnect the batt.?
There are many "rules" for storing cars for long periods of time, number one being it should be stored indoors, or at the least under cover, [car port not car cover, unless indoors or under car port] all fluids should be changed, gas tank should be filled, get the tires off the ground but do not use jack stands unless the the stands are also holding suspension, hanging the tires and suspension is not a good idea, a simple way is to just put 2x6/2x8 planks under the tires.
There are a few more good ones I can suggest once I get a better idea of where car will be stored.94
Old Sep 7, 2009 | 06:56 PM
jin4g63's Avatar
The life of the battery will shortened if its not charged and the trickle charger is only 15bucks and a new battery is 50bucks
Old Sep 8, 2009 | 06:04 AM
fcm's Avatar
fcm
Old Fart
$50 is going to be the last thing you will need to worry about if all you are going do is connect up a trickle charger and park it for a year.
But it's your car so....
All you need to do is run a lead from the constant power free pin on under dash fuse box to the lighters center terminal, [pos.(+)], even easier, pick up a lighter housing and connect it to the constant power free pin and ground as a temporary plug in, that way you will not have to mod the stock lighter at all. 94
ak47autolock
20
Sep 25, 2006 03:38 PM
1999all_motoR_teg
Dec 4, 2004 02:09 PM
onyx00
Sep 8, 2004 06:24 PM
2000Accord5sp
Dec 19, 2002 11:04 AM
SuperRice
Oct 31, 2002 01:53 PM
