Do any cr-v come with the rsx s engine in them
or whats the best engine to get in the cr-v what year im looking to get one shortly as a daily driver but want the most stock hp without head swaps or whole enigne swaps thanks
No, TSX would be the best swap for the CRV IMO, But its never going to be quick. Leave it alone and buy a civic to mod.
Hahah do you call a civic with an intake and header a modded civic? Not tryin to be rude but there's a reason why alot of people don't boost a cr-v
once again it was a simple question im buying a daily driver if you read the first ****ing post and no it doesnt have a intake and exhaust and if you ask around milwaukee and racine you will hear that matt tobias has built some nice fast **** dont come asking me when you want that polished stainless intercooler pipe welded for your custom setup or come crying when you get beat by the fully built ca18 in the red 240sx done with this site the whole reason we never ****ed with it in the last 8 years ill leave it to the amatures peace!
NO to your first question!
you secound question makes no sense because you said you dont want to do an engine or head swap so your either stuck with one of these engines below.
imo the K24a1 is a good *** engine that I THINK is excelent for boost exspecially when you turn it into a hybrid. k24/k20
[edit] K24A1
Found in:
2002-2006 Honda CR-V
Displacement: 2,354 cc (143.6 cu in)
Bore and Stroke: 87 mm x 99 mm (3.43x3.90 inches)
Compression: 9.6:1
Power: 160 hp (120 kW) @ 6000 rpm
Torque: 162 ft·lbf (220 N·m) @ 5200 rpm
Redline: 6500 rpm
[edit] K24Z1
Found in:
2007- Honda CR-V (RE3, RE4)
Bore and Stroke: 87 mm x 99 mm (3.43 x 3.90 inches)
Compression: 9.7:1
Power: 166 hp @ 5800 rpm
Torque: 161 ft·lbf @ 4200 rpm
Redline: 6500 rpm
[edit] K20A4
Found in:
2003-2005 Honda Accord (UC1)
2006-2008 Honda Accord (UC3)
2001-2007 Honda CR-V (RD5)
2000-2003 Honda Stream (RN1)
2004-2007 Honda Stream (RN3)
both of you calm down!!
what would be your point of putting an rsx motor in the crv if you are just gonna use it for dd?..the k24a1 motor is better anyway unless your doing a head swap which would be dumb imo to put in the cr-v...i have seen multiple elements with swaps and modded but crv, no...keep it stock imo and use it the way it comes
p.s. did they pass a law that required Wisconsin residents to write using only run-on sentences?
My friend is putting down 602whp on a 100% stock k24a4... why not mod it if he wants to? As you said there are more than enough turbo elements out there all you would really need is turbo kit or just simple built bottom end n/a build. It does seem a bit useless tho depending what he wants out of the car.
i wouldn't DD a car with 602 WHP either. with that amount of power, you're easily spinning all the way through 3rd and possibly 4th, but to each their own. i like my DD's being headache free and easy to drive.
^agree with above. 602 WHP for a dd is a bit too much for me. I also would like to know what car he's getting 602 WHP out of a k24a4. Just curious, not trying to be a dick about it.
i know that my local tuner here "the hamburgler" was at 480hp in his ls/vtec eg and even that was pretty tough to dd, clutch wise mainly, if its boosted its not hard to drive it while keeping it out of boost, but then you go no where
So what the guys a noob everyone acts like they were born knowing everything about hondas. Stop being dicks! You cant even post without some smart *** know it all trying to beat you down or correct your grammer.
No crv's don't come with rsx engines.If I were you I would keep the k24 engine that comes in your crv,assuming it's not a first gen with a B20 and go from there.They have a lot of potential
you new mods close a thread about some one asking where to buy JDM emblems with a good thread title for searching, but keep posting pointless comments in this thread. WTF? This should be closed.
A mod tip for you, before you think a thread should be closed do a HT search on it. If results are not clear reply to it with something useful.
Your "job" is to make it easier for users to get information, not to be dicks for no reason.
^ well said playa. and my car rides smooth thanks to u and dave on setups for lowering the damn thing. i like turns now and not going straight haha.
I can't believe that we are in a EP3/DC5 forum talking about CR-Vs!
There is an SUV section on HT, I am pretty sure they have a picture thread there!
As for the aemciv, I here your point but you have to understand that this is also a tech forum not a where to buy or where can I find type forum! We have a fs/wtt/wtb thread for those specific types of questions! Also when you do a search don't only do a search try to find thread but do one searching posts! You will be surprised on what you will find...
Also as Josh mentioned if you have a comment/complaint to make don't be shy to PM us... that is what we are here for! I don't mind talking it out and coming up with a solution that can help everybody...
