Conversion Possibilities...?.
Old Sep 6, 2009 | 02:39 PM
Badboyforero's Avatar
Icon3 Conversion Possibilities...?.
Ok. I have a 1992 Honda Civic Hatch and just recently made a deal with a buddy for a f2.0B Engine. "he did the straight h2.2a engine swap in his accord.
Couple of rims and tires and i now own a f2.0B.
I was told that i could do a head swap out to the h2.2a and increase drastically everything about this block. I was also told to swap out the stock pistons and rods for RSX style.
1. Is the feasability there?
2. Will this do very bad things "in a good way. hehe".
3. After the conversion, will i be able to go Turbo. Without damaging things.
4. How much "hacking and slashing" will be involved.
If people have in fact done this swap out, is it a better conversion than just swapping totally over to the h2.2a?
Thank you for your advice.
Old Sep 6, 2009 | 02:57 PM
bar'dh22's Avatar
Default Re: Conversion Possibilities...?.
for onw its f20 no dot and h22 no dot you need to do a lot more research before making carppy threads like this all the info is in the sticky's go do some reading
Old Sep 6, 2009 | 03:13 PM
98civdx's Avatar
Master Detailer
in my opinon this swap is pointless, but this is just me. its going to require basicly the same parts as a h22 swap, and there will be some cutting.
i have heard of people useing the rsx pistons and rods but i dont know for sure,
if i were you i would definely do some reading on this swap, i dont think the f20 has been done alot but there is info out there for it.
but as this guy above said there is no . in it, is f20b or h22
Old Sep 6, 2009 | 03:48 PM
For Clarification purposes only.. Thanks for your input. I put the periods.. "." in for the purposed of f2.0Lb style block. in other words. 2.0L block.
block style being fb. thanks for clarifying my ignorance though.
I also did the reading. I simply posted for assistance. the f20b conversion with the h22a head is and has been done before. I wouldn't simply post to be a moron. Located in alaska, getting the technical advice for doing something like this is the smart thing to do. Even though i will be doing it through my shop.
Miss Chillz
Mar 26, 2014 05:42 PM
civic2.2
Sep 24, 2005 05:04 PM
GrdStorm
Nov 23, 2003 06:32 PM
honda4life4456
Oct 28, 2003 05:44 PM
sacredc0w69
May 13, 2003 06:30 PM
