HELP Brake Lights Stuck On ??
Old Sep 6, 2009 | 12:07 PM
93grayeg's Avatar
Default HELP Brake Lights Stuck On ??
my brake lights are stuck on in my hatch??? really confused . . . tried hitting the brakes and see if it would go off. . . pulled the connecter off the back brake light and pluged it back in and still on??? im lost
Old Sep 6, 2009 | 12:47 PM
ef2 pimp's Avatar
Default Re: HELP Brake Lights Stuck On ??
there is a blue piece that broke off from between the brake pedal and brake light switch on the pedal assembly. you can either put a new bolt,tape a penny or dime or buy a new plastic piece and put it back on and it should compress the brake light switch and turn off the brake lights normally.
Old Sep 6, 2009 | 12:51 PM
kit50si's Avatar
this happened to me years back. there's a rubber stopper on your brake pedal you have go under the dash look at the brake pedal there should be a rubber stopper that hits the button when you let go of the pedal. you have to go to the dealer for that part.
Old Sep 6, 2009 | 01:14 PM
GSR CRX's Avatar
kinda off topic but the same exact issue. have any of you ever experienced this problem but on the clutch safety switch? i was stumped on why my car didn't want to start up until i found more of those odd blue pieces of plastic. just thought i put that out if anyone ever experiences this starting problem.
Old Sep 6, 2009 | 01:18 PM
ef2 pimp's Avatar
the one on the clutch should be to activate your cruise control.
Old Sep 6, 2009 | 01:23 PM
beansandrice's Avatar
rustbucketrex's Avatar
I have had the "blue crayon" pieces on my floor mat for the brakes and the clutch safety switch. The brake light issue is listed under the FAQ but I'm not sure if the safety switch issue is listed there. They both use the same OEM part to fix them and I keep a couple of them in my glove box just in case.
Honda part #46505-SA5-000
Old Sep 6, 2009 | 01:26 PM
ef2 pimp's Avatar
my cruise control went out and i had to replace the same blue piece that broke off to the clutch pedal to re-activate my cruise control.
Old Sep 6, 2009 | 01:30 PM
mother ef-er's Avatar
Originally Posted by beansandrice
.. never ends.
Old Sep 6, 2009 | 01:37 PM
93grayeg's Avatar
ok guys thanks a lot. . . I just looked on my floor and seen blue plastic pieces laying there. . so thats what happend. . .but I cant seem to find where your talking about under the dash?? I was under there and didnt see anything. . . and whats the best temp. fix for this untill I go to the dealer because it drained my battery and now its completley dead. . . ???
Old Sep 6, 2009 | 01:51 PM
ef2 pimp's Avatar
look at your pedal assembly under the dash. press in the brake pedal and you should see a small opening on the brake pedal and a brake switch that has a white butten on it. the broken blue piece belongs in the hole on the brake pedal. since its missing it doesn't compress the brake switch therefore your brake lights stay on. put something in the hole on the brake pedal temporarily until you can get the missing piece from a auto parts store or the dealer. this will cause you brake lights to turn back off normally.
Old Sep 6, 2009 | 02:08 PM
super glue a few pennys to where the blue plug is supposed to be.. thats a permanent fix. and ony costs 3 or 4 cents and a tube of super glue.
Old Sep 6, 2009 | 04:35 PM
93grayeg's Avatar
issue fixed . thanks guys
Old Sep 6, 2009 | 04:40 PM
.Manny.'s Avatar
Touching My Member
i always use a small 10mm bolt and nut.
Old Sep 6, 2009 | 08:09 PM
D16SiHatch's Avatar
Originally Posted by mother ef-er
super glue a few pennys to where the blue plug is supposed to be.. thats a permanent fix. and only costs 3 or 4 cents and a tube of super glue.
for some reason i found that moderately humorous lol
Old Sep 6, 2009 | 08:53 PM
93grayeg's Avatar
its even funnier because thats what I did to fix it, used gorilla glue. its not going to come off again , For sure
Old Sep 8, 2009 | 06:32 AM
popejooie's Avatar
screw the blue crayons. ghetto rigged is more reliable
Old Sep 8, 2009 | 08:45 AM
smokeyjpn221's Avatar
sounds to me like your brake light switch is stuck on...you might wanna check that out bro. good luck
Old Sep 8, 2009 | 02:15 PM
johnnyonth3spot's Avatar
You guys with this brake stopper problem make me laugh my gf had this problem 2 years ago and figured it out on her own and she's dumb as a rock.
Old Sep 8, 2009 | 07:30 PM
93grayeg's Avatar
yeah well your girl friend must me smarter than half the people on here then . you know what makes me laugh? how I said I solved the issue and people are still talking about it
eTiLiKo
Aug 9, 2018 03:03 PM
asocallocal
Aug 29, 2010 07:00 PM
BigAnteg
19
May 21, 2009 05:44 AM
musclehead954
Feb 27, 2008 10:28 AM
Agent Daimon
11
Jul 19, 2002 08:39 PM
