ls vtec question
Old Sep 6, 2009 | 09:20 AM
sh!ft's Avatar
Who the fack changed my title?!
Default ls vtec question
OK so i was told i have to go 10 over on my cylinder walls and i wanted to know, whats the biggest bore i can go with using a block guard. and should i stick with the b16 Pistons i originally had or should i use some other tyPe of Pistons
Old Sep 6, 2009 | 09:21 AM
Ls_dx's Avatar
Default Re: ls vtec question
If you have to go .10 over, then you need new pistons... and the block guard... I dont think those are a good idea.
Old Sep 6, 2009 | 09:35 AM
sh!ft's Avatar
no what im saying is, as far as decency goes, should i stay with the b16s or get different ones
Old Sep 6, 2009 | 09:47 AM
Ls_dx's Avatar
The b16 (p30) has a nice dome on it makes for some good compression on a NA build.
Old Sep 6, 2009 | 10:22 AM
sh!ft's Avatar
o ok well im running pr3's right now. any difference in height differences between those and the p30's or basicly the same?
Old Sep 6, 2009 | 10:51 AM
DDTECH's Avatar
Biggest bore on stock sleeves recommended is 82mm.
Do .20 over if you plan on just doing a complete rebuild at least
Old Sep 6, 2009 | 02:28 PM
sh!ft's Avatar
would that make a difference as in terms of disPlacement
Old Sep 6, 2009 | 04:40 PM
DDTECH's Avatar
Depending on the crank use. Boring to 82mm and using a ls crank will put your block at a 1.92 Liter motor.
kotton909
Mar 21, 2011 10:27 PM
89s1
Sep 20, 2006 06:11 PM
Roy2377
Jan 12, 2005 07:50 PM
Chris Benoit
Aug 10, 2003 09:22 PM
ls_vtec_b18a1
Oct 14, 2002 05:34 PM
