2001 Acura MDX
I've noticed several problems with my transmission.
One being that the shifts between first and second, second and third are very hard. It sort of stutters to grab kind of like its slipping then grabs. And when it does grab after about a second of slipping it makes the car jump slightly. It also bangs hard when I put it into reverse. CEL is on but I haven't had the time to scan it. Before I go I'd like to get an idea of what could possibly be going wrong.
Whats the problem with my transmission?
Honda will tell you not to flush.
http://www.aboutautomobile.com/TSB/2001/Acura/MDX
Ctrl+F and type in transmission.
why are you waiting? go have the obd II code scan for free at your local autozone... let them reset the light while you're there
goto the following link for your vehicle; it seems there's lots of problems w/ that vintage on the other site
http://www.mdxers.org/forums/forumdi...php?forumid=73
what's the condition of the trans oil? did you do a drain/refill yet? w/ these hondas, it's better to do more frequent transmission oil changes than what's required in the owners manual
how's the condition of the trans and engine MOUNTS? slightly off-topic, but lots of owners w/ this model are having premature failures, i'm guessing due to not using the parking brake to hold the vehicle in place and that puts a stress on the transmission and/or mounts
KaranBagga
Acura TL, RL & ZDX
25
Feb 22, 2014 06:46 PM
