blue smoke...updatered
after about 4 miles of driving without the oil cap on..i started getting blue smoke. can this just be the headgasket? or...oil pump and piston rings..?
*edited*
ok. compression test was..
cyl #1 90
#2 30
#3 120
#4 150............yeah...so i took the head off and the #1 piston can be rattled a bit back and forth. #4 does that too(#1 and #4 TDC up)
so the piston rings are bad?
*edited*
cyl #1 90
#2 30
#3 120
no i left the oil cap off. and drove 4miles. and was like uh...blue smoke wth. so i got home and found it out and put it on. i drove around later that night. same thing. but it got worse. im guessing piston rings but yeah. compression test 2morrow or tuesday. if its bad...im partn it all out.
that shouldn't mess with ur engine at all
thats almost like puting a oil catch can system excwept everything is blown out,tru ur oil cap hole.
drive it around 4 a while n let the oil burn off everything
when i put the clutch in..it dies. it wont stay running unless i keep my foot on the gas. and ontop of this. my car was tuned by a overconfident noob.
cyl #1 90
#2 30
#3 120
cyl #1 90
#2 30
#3 120
Wow, that thing must have been running like **** if it had 30 psi in one cylinder.
yeah. its just alot of work. you think i can get away with just replacing the piston rings? can i reuse the main bearings?
the motor was hottanked and honed 50 miles ago. the crank was balanced etc
Was this engine rebuilt 50 miles ago? Sounds like there is something seriously wrong. Just throwing rings at it is probably not going to fix it. You should have done a leak down test when the head was on to determine where the compression loss was.
well 3 dif people tuned it throughout the year. and e85 being way below 10.1 afr i kept having to change the oil becuase the rings were gettin washed out (gas in oil). awhile ago i had an injector stick open(flooding teh cylinder)a few times until we found the eletrical problem which caused gas to get sqeezed pass the rings. it idled super rich while 3 dif people tried to tune it which didnt help at all.
it sounds like you've effectivly torched your rings. the question is, how much play is between the pistons and cylinder? a little is normal, anything more than normal and the engine will never run right. It can also wear out rings rapidly and cause serious cylinder wall damage.
Even if you don't want to, it needs to be measured for potential oversizing.
andystart
14
Oct 15, 2004 08:52 AM
tianporn
10
Jul 20, 2004 11:24 AM
