93 del sol ign switch help!!
i need some help.. my gf lost my keys for a 93 del sol s... i went to kragen to see how much the switch was and the guy said 342.. then online i found the cylinder for less than 20 bucks. does the 93 have a chip in the key? or can i just replace the cylinder?
need help asap.. thanks
you can just replace the cylinder, hondas didn't start using a transponder based security system until 2000 on civics. and no del sol used transponders to my knowledge, swap the ignition cylinder, and grab the corresponding door lock cylinder and trunk cylinder to make them all the same.. *OR* you can just have your cylinders all re-keyed to match your ignition cylinder, but the catch is you need the key for those tho lol.
Dude i really don't mean to jack your thread, but i started my own a week ago and 37 ppl looked at it and nothin..... But does anybody know if i can use a ignition assembly out of a 95 automatic Dx coupe in the same yr manual cx hatch?? any opinions would be helpful. thanks
Tk42
Mar 3, 2012 05:51 AM
9395delsol
Jul 19, 2007 04:40 PM
