Exhaust creek is driving me insane
Old Sep 5, 2009 | 05:35 PM
NACvicSi's Avatar
Default Exhaust creek is driving me insane
My exhaust has started creeking and rattling especially when I first start it up and at a stop. I climbed under it to day while fixing the brakes to find the culprit and it was the small bracket that holds the exhaust up. I can't find any way to get it off without cutting it. It's the small piece of square metal attached the the bracket that isn't even doing anything rattling. Any ideas? You can see it in this picture:
Old Sep 5, 2009 | 05:58 PM
ccarey's Avatar
Default Re: Exhaust creek is driving me insane
I cant see any picture!!
Old Sep 5, 2009 | 05:59 PM
ccarey's Avatar
my bad just took a while to load ha ha
Old Sep 5, 2009 | 07:52 PM
worlds-slowest-EG's Avatar
try to oil it. a little wd40!
Old Sep 5, 2009 | 08:03 PM
NACvicSi's Avatar
All the black stuff you see is grease. Didn't help at all.
Old Sep 5, 2009 | 08:07 PM
ccarey's Avatar
in the pic it looks like it's spot welded, is it?
on the side of the lower open ended square box
Old Sep 5, 2009 | 08:13 PM
No offense but it looks like a muffler shop job, and a lazy one at that! if you recently payed some1 to do that i would take it back and have them put a factory style rubber hanger back on it. you can get the rubber part from any auto parts store and they should be able to make the studs.
Old Sep 5, 2009 | 08:29 PM
NACvicSi's Avatar
Yeah it is, that's where it's welded to the exhaust pipe.
I didn't have this done by any means. It was like that when I bought it. I plan on changing the exhaust out to a spare I have anyways so I think I will do this. So the rubber hangers are just available at any auto parts store?
Old Sep 5, 2009 | 08:34 PM
yeah around 5-9 dollars. but like i said the studs need to be there too like at the rear (if they're still original)
Old Sep 5, 2009 | 08:35 PM
ccarey's Avatar
yeah take the bracket off, and get hangers, and rubber. if you want to wait in the mean time, maybe get some brake cleaner clean off all the grease, and re-grease it till you get the exhaust you want, with the right hangers
Old Sep 5, 2009 | 08:39 PM
Btw, that hanger wasn't made to be welded on to the pipe, it should have a steel or rubber strap from it around the pipe
Old Sep 5, 2009 | 08:42 PM
NACvicSi's Avatar
Yeah you can see where it was cut. I love when idiots work on cars.
Old Sep 5, 2009 | 08:52 PM
ccarey's Avatar
ha ha you should see what some of the people have done to the car i'm working on. it will amaze you.
Old Sep 5, 2009 | 09:20 PM
danielfleenor's Avatar
i had a vibrating prob... **** does get annoying! All mine was rattling against the sway bar
Old Sep 6, 2009 | 05:45 AM
NACvicSi's Avatar
Yeah my shifter is vibrating against my exhaust shield or just loose and makes a noise also so I have two annoying noises. Not to mention some random squeak on the inside of the car. That should be a fun one to track down.
j-rome
Honda Civic (2006 - 2015)
Sep 30, 2009 06:58 PM
Zector
Jul 22, 2009 12:00 AM
Dizzypop DA
Nov 29, 2007 11:34 AM
Black DC2
Nov 21, 2005 11:13 AM
GUNNER666
Mar 11, 2004 10:26 AM
