98 LS turbo // general quiestions //
Old Sep 5, 2009 | 05:14 PM
gsorls's Avatar
Icon6 98 LS turbo // general quiestions //
i just bought a 98 ls and i have a few quiestions about turboing the stock engine. how much boost "safely" is the lower end going to hold on the stock internals. and what do i need to do to the computer to get the car to not spaz out when i hit boost.
i have never used forced induction before so im rather green on the subject. any sugestions or general knowledge would be great.
Old Sep 5, 2009 | 06:19 PM
20-EM2-05's Avatar
Default Re: 98 LS turbo // general quiestions //
If you want "safe", it all depends on your turbo. Usually a stock LS block can usually handle 8-10psi safe. But depending on the turbo size. Running 8-10psi will usually run you 230-270WHP with a good tune.
Just tune the car and you will not spaz out when you hit boost.
Old Sep 5, 2009 | 06:52 PM
00IntegrAllmotoR's Avatar
HT Black OPs
AHHHHHHHH!!!! why do people say psi?? Have to take into the fact of which turbo he is using. https://honda-tech.com/forums/forced-induction-16/lst-ls-t-turbo-b18a-b18b-setups-1323059/ Read and learn.
Old Sep 5, 2009 | 07:08 PM
20-EM2-05's Avatar
Originally Posted by 00IntegrAllmotoR
AHHHHHHHH!!!! why do people say psi?? Have to take into the fact of which turbo he is using. https://honda-tech.com/forums/showthread.php?t=1323059 Read and learn.
That's exactly why I said "The size of the turbo". I never said "8-10psi is safe using all turbos". Re-read what I said.
I have read and I have learned many times haha. He was talking on stock internals, he wasn't talking about having the bottom end modified before he slaps a turbo on it.
Old Sep 5, 2009 | 08:55 PM
jhammond_82's Avatar
Reject Papi
you can get some pretty decent numbers from a stock ls. look in the forced induction forum. there's guys there, bone stock ls pushing 380 hp. as it was already said. get it tuned.
Old Sep 5, 2009 | 09:46 PM
gsorls's Avatar
ok i got the idea from the other forum, would a S100 be easier use for a noob "like me" compaired to a S200? or could use of a different system be more bennifical in my application?
Old Sep 6, 2009 | 06:50 AM
HT Black OPs
Originally Posted by 20-EM2-05
Usually a stock LS block can usually handle 8-10psi safe. Running 8-10psi will usually run you 230-270WHP with a good tune.
I did read it just fine, theres to many factors in a setup to accurately say this. And the numbers are amazing that u pull out of no where. Yes u said which turbo u use, cool. But where did u get 8-10psi and 230-270whp?? Theres lots of LS setups in the turbo forums running much higher whp on stock internals SAFELY.
sonne_side
Mar 31, 2009 08:23 PM
peacemaker
Oct 25, 2007 02:22 PM
TVietEBoyG
Aug 14, 2007 04:30 AM
redlseg
Aug 2, 2005 07:55 PM
Doostur
Oct 3, 2004 09:52 PM
