b18c1 block b16a head
Old Sep 5, 2009 | 02:17 PM
91lsteg's Avatar
Default b18c1 block b16a head
ok i know there are 100 posts about this kind of build. but what i am curious about is the head hasket. i found a site
http://www.c-speedracing.com/howto/c...c/compcalc.php
and the compression table states oem bseries gaskets. 1 layer,2 layer, and 3 layer.
with my set up that im going 4 is this
jdm b16a head oem
usdm b18c1 block oem
will run a zex wet kit also. 55 shot
with oem 3layer 9.80 comp
with oem 2 layer 10.03 comp
with oem 1 layer 10.26 comp
now my question is. how safe is it 2 run a 1 layer gasket?
will i have possible piston slap
or what layer or thickness should i try and run with this set up
Old Sep 6, 2009 | 12:34 AM
king06's Avatar
Default Re: b18c1 block b16a head
There's no such thing as an "oem" one or two layer gaskets.
Well, there is, but they just take a stock one and take the middle out(Spoon).
I don't believe any of those gaskets will allow you to come in contact with the pistons since its a stock piston motor.
Just make sure you run the right plugs and retard your timing when running the nitrous.
Old Sep 6, 2009 | 04:37 AM
00Red_SiR's Avatar
All Motor Mentor
I'll bet that if you cc'd the combustion chambers in that head, they'd come out larger than the C-speed calculator says they are. If you factor that into the equation, your compression will be even lower than you thought.
Old Sep 6, 2009 | 12:03 PM
91lsteg's Avatar
yeah i was curious but i thought since everything was stock/ the combustion chambers and pistons/deck height it would be fine. i have a comclete b16a(jdm) and a b18c1 usdm
if id use the p30 pistons out of the b16a would that raise my compression. im trying 2c what would be a good streetable set up using the parts from each of these.
Old Sep 6, 2009 | 12:57 PM
00Red_SiR's Avatar
All Motor Mentor
changing the pistons to something like the p30 is a good place to start for more power.
Old Sep 7, 2009 | 06:52 AM
91lsteg's Avatar
sounds good. with a 2layer gasket and p30 pistons. does this compression look correct
11.64.
if so what kind of differance would this be 2a stock p72 piston?
Old Sep 7, 2009 | 09:21 AM
00Red_SiR's Avatar
All Motor Mentor
if you plug those changes into the C-speed calculator, it will give you a good idea of where your comp ratio will be. I'd cc your head after you install the pistons to really see hwat you'll be looking at.
Old Sep 7, 2009 | 04:54 PM
all-mtr-teg's Avatar
Decide what cams you're going to use before you decide a compression ration goal.
Old Sep 8, 2009 | 11:19 AM
91lsteg's Avatar
well since its a total buget build either gsr cams. unles i can find cheep springs and retainers then ill go itrs. 00 model
ev94eg
Sep 29, 2011 09:24 PM
egkyran
Dec 31, 2007 08:48 PM
Krucial_Ek9
Jul 23, 2007 05:48 PM
Turbocivic94
Jun 4, 2005 10:45 PM
Riptide101
Apr 12, 2003 10:33 AM
