Best Plugs for f22b2?
Old Sep 5, 2009 | 10:22 AM
detailzdelivere's Avatar
Default Best Plugs for f22b2?
Just looking to do a nice tune up on my dd stock f22b2... Now on the Audi i live by NGK's do they offer a plug for my accord? Or do you guys recommend something else? Also what should the gap be?
Old Sep 5, 2009 | 10:33 AM
TOO MUCH TORQUE's Avatar
Default Re: Best Plugs for f22b2?
you will never go wrong with NGK on hondas
i'm running NGK iridiums on my integra right now, just dont run BOSCH
Old Sep 5, 2009 | 12:22 PM
GhostAccord's Avatar
NGK or Nippondenso are the suggested plug for Honda engines.
NGK plugs F22B2;
For normal climate conditions;
V-Power - ZFR5F-11
G-Power - ZFR5FGP
Laser Platinum - PZFR5F-11
Iridium IX - ZFR5FIX-11
For hot climates or continuous high speed driving;
V-Power - ZFR6F-11
G-Power - ZFR6FGP
Laser Platinum - PZFR6F-11
Iridium IX - ZFR6FIX-11
Gap = 0.043"
Old Sep 5, 2009 | 08:30 PM
nicolaselias's Avatar
Loved
Community Favorite
right now I personally run the ZFR6FIX-11 on my F20B2 engine in hot climate...
so far no issues at all...
best value for money, I vote for the G-Power line from NGK...
Old Sep 6, 2009 | 03:03 AM
nicolaselias,
Have you ever considered running a set of ZFR7FIX-11s in the F20B2? It would probably run a little bit better in the heat vs the 6F. The F22B1 & 2 only have the two plug heat ranges listed in the Honda manual. The F20B2-3 have 3 heat ranges listed and the 7F is the preferred range for hot climate or continuous high speed driving.
Old Sep 6, 2009 | 07:53 AM
1997accordex's Avatar
ngk's are the best i have tr55ix's in my f22b1 and they are great
Old Sep 6, 2009 | 08:08 AM
That plug number is for a Camaro/Firebird. The gap is 0.040. But hey if they fit and you aren't having any problems...why not. Why did you go with them vs the Accord plugs. Are the packs of 4 cheaper?
Old Sep 6, 2009 | 05:53 PM
BBallz24's Avatar
I emailed NGK about plugs one time.....they replied back with the ones listed for stock H22, but when I run turbo the guy recommended one for an Audi. Same threads, just different heat range. So this may be the same for the Camaro one listed above?
Old Sep 6, 2009 | 06:30 PM
nus_dogg's Avatar
I ran NGK Iridium plugs on all my motors I've had; best bang for the bucks.
Old Sep 6, 2009 | 06:54 PM
i got trx55ix's for my pontiac but wound up not needing them i then regaped them to 1.1 so they would have the proper gap i know its not the right ones but i already had them and i figured i would try them 200mi later no problems and i didnt have to buy new plugs probaly not the best way to do it but it works.
OMG
14
Jul 15, 2014 08:17 AM
FRKWOO
13
Apr 5, 2009 06:49 PM
veritasaequatis
14
Feb 6, 2007 03:08 PM
coolrace05
Nov 29, 2005 02:39 PM
XEF-9X
Jan 3, 2003 09:43 AM
