trouble code p 1337 ignition system. or misfire.
Old Sep 5, 2009 | 07:10 AM
Crazed-Sol's Avatar
Default trouble code p 1337 ignition system. or misfire.
I read the code and have determined that the code is related to the ckf (crank fluctuation sensor). im using an obd0 jdm b16a block. so there is no ckf sensor. ive been told if i perform the ckf bypass trick, it will get rid of the CEL, my question, does the crank fluctuation sensor make the engine run funny? if so, what problems can the crank fluctuation sensor cause? idle? loss of power? limp mode of some sort? im curious what the ckf sensor can actually affect, thanks.
Old Sep 5, 2009 | 04:44 PM
Crazed-Sol's Avatar
Default Re: trouble code p 1337 ignition system. or misfire.
anyone have any idea? it doesn't seem like my car runs like crap.. but maybe it is. just looking for input guys
Old Mar 12, 2013 | 08:54 PM
Hurtadok7's Avatar
Hey man . Did you figure out the problem yet ? I'm having the same exact same problem. Car does feel like the one I used to drive. Would replacing the sensor fix it ?
rbizzell30
Jul 10, 2008 09:41 PM
Silver89crx
Dec 3, 2007 05:44 PM
saywhat
Dec 5, 2004 09:41 PM
mraudio13
Sep 19, 2002 05:34 PM
wickedxboi
Jul 28, 2002 08:34 AM
