need help is this the tranmission problem?
hey everyone, i need help finding out what might be this cause. I be hearing noises coming from my transmission but then once i step down on the clutch it goes away. and when i let go to idle in neutral the noise comes back. could it be the throw-off bearing? pilot bearing? tranmission itself? or maybe the pressure plate could be the cause? i have already changed the clutch disk but not the pressure plate. it's like a shattering noise.
I am actually having the same problem and was about to start a thread about it. When I'm sitting still and press the clutch in there is no noise, but when I let the clutch out it tends to make a kind of a bad noise, but not all the time. It sounds like something is possibly vibrating. I was thinking that it may be the throw out bearing. My car has 170,000 miles on it, so the bearing may be vibrating or just plane bad.
he's rite.. its ur input shaft bearings......missin bearings they broken...thats wat ur shattering noise is.... when its spinnin ..its hittin each other
00siandrew
Apr 13, 2006 05:09 PM
