91 ef with b18b LS helP!!
want to know wat T bracket to use because the one it has broke and also gettin a code 20 and code 9 dont know wat the electric load detector mite be and if the cylinder sensor will afect my engine the car is running on a pm6 ecu gunna do the obd0 to 0bd1 conversion with a p75 later but help me with this thanks
the ELD code is probably a bad ground. least thats been my experience with that code, i have had it a few times and its always been grounds.
ok il use dat T bracket and um was also wondering if i can use a DA core support on my EF and will a code 9 have any effect on the engine???
thanks i just notice my distributor one of the cables was cut and the fan switch is added directly to one of the distributor cables can that be why im throwing a code 9
well there's certainly a pretty good possibility the two could be related. can't imagine why someone would tie the fan switch into the dizzy wiring though.. some people just do some janky stuff i guess lol.
any ideas where i can wire it up too idk why is like that to tell u the truth i dont see the other end of the connection either the one to the harness
love_ek9's
21
Nov 25, 2010 10:53 PM
