My attempt at using a velocity stack....
Old Sep 4, 2009 | 01:43 PM
brokenojoke's Avatar
Icon6 My attempt at using a velocity stack....
I picked up a BPI stack a couple of weeks ago and here is my attempt at trying to use it correctly. I am also using a new air filter that has the 6inch inlet to fit around the stack.
Current setup is
B16a stock bore stroke
CTR pistons/cams
portflo headwork & components
ITR intake manifold
Spoolin header
no cat w/ 2.5 exhaust
tuned on s300
cams gears at +4intake -4exhaust
neither head or block have been milled
My current intake setup is 2.75 inch tubing w/ AEM filter at the end of it.
I'm going to try to use the stack in three different ways and check it at the dyno.
One is to just get a 3inch to 2.75inch reducer and just put the new stack and filter on the end of it.
The next is a complete 3inch aluminum cold air setup with the filter kept in the fender well and a 3inch to 2.75 reducer at the T/B.
The last is to make a 3.0 inch shortram intake that will eventually get air from a headlight box if this design proves to hold its own. This design will also use the reducer at the T/B.
I currently make 172hp/110tq@8500rpm.
I hit the dyno this week hopefully.....
I'll post up dyno charts after my runs....
Old Sep 4, 2009 | 01:58 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default Re: My attempt at using a velocity stack....
road racer, eh?
is this a crx or integra shell? for the stuff i can see, nice work
Old Sep 4, 2009 | 04:44 PM
dlaub25's Avatar
Off topic but...Did you have made/make the front brace yourself? Or, was it off the shelf?
Old Sep 4, 2009 | 05:00 PM
Local fabricator made it. There is another in the rear. I save a grip of weight using them compared to the stock bumper supports.
Old Sep 4, 2009 | 05:08 PM
dlaub25's Avatar
Very nice. That's something new to me.
Old Sep 4, 2009 | 05:32 PM
DDTECH's Avatar
Looks good.. Just run it str8 out tho, you'll make more power, instead of making the air move in curves.
Old Sep 4, 2009 | 06:55 PM
95skunkedgsr's Avatar
yea i wanna c how it turns out thought about playing around with it on my gsr teg.. jsut dont have the extra cash for dyno time laying around
Old Sep 6, 2009 | 03:08 PM
If you wanna check out a couple more pics of the bumper supports.......
https://honda-tech.com/forums/road-racing-autocross-time-attack-19/ef-weight-savings-repleacement-bumper-supports-2641229/
rdeezy78
Jan 23, 2007 02:02 PM
Gargoyle
Jan 23, 2007 01:19 PM
Iomega01
Aug 9, 2005 12:51 PM
krack
Jul 1, 2004 07:47 PM
Krypto
Mar 3, 2003 02:46 AM
