Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
~$$$BISIMOTO ENGINEERING PRODUCTS$$$~
Old Sep 4, 2009 | 01:42 PM
Sales@Bisimoto.com's Avatar
Default ~$$$BISIMOTO ENGINEERING PRODUCTS$$$~
Bisimoto H2B / F2B Kit
PM for price!
Developed, engineered and manufactured due to popular demand! Unlike the competition, a rigorously tested plug n'play system. Kit comes with signature zinc oxide plated half moon plate, SFI approved aluminum flywheel with serrated heat treated friction plate, custom pillow block mount for half shaft, 8.8 grade bolts, solid dowels, and slave cylinder spacer. No kit on the planet even comes close!
Features:
–Precision machined
–Steel plate signature half-moon design
–Complete, with stage options (with or without EG chassis mounts)
-Custom SFI approved flywheel (no dangerous spacers)
-Flywheel also incorporates timing marks
–Field and race tested
–Design from Bisimoto: drag Honda-Honda adapter plate pioneer, and the Evolution Industries.
Benefits:
–H22/H23/F22/F23 power without the quirky H-based transmission
–Improved power-weight ratio
–Improved aftermarket gearbox support
–Designed to withstand the rigors of racing and street duty
-The only SFI approved kit on the market
–Simplicity
Bisimoto H2D / F2D Kit
This is the very same plate system that won the IDRC 2003 all motor championships, and showcased in the June to August Sport Compact Car magazine! Many may ask, "Why the D-series transmission?" These transmissions are plentiful and very cost effective. Since many popular Honda chassis come with these transmissions from factory, factory style axles, mounts, shift linkages, and gearbox sensors can economically remain intact. Strength of the individual gears is also a big plus. Unlike their B-series brethren, D-based gears are "stubby", and take well to abuse.
The Bisimoto Adapter units, the flywheel, bolts and plate, have been rigorously tested in racing environments for 4 years: a claim which imitators cannot replicate. Metallurgical testing has occurred to ensure the perfect components.
The Bisimoto H2D and F2D kits comes with the signature "half moon" adaptor plate, aluminum flywheel, and custom plate bolts. Factory dowel pins and flywheel bolts should be utilized. A 0.5" x 7" strip should be shaved from the block/pan assembly to allow access for the driverside axle shaft. Depending on the chassis frame, use of an aftermarket crank pulley may be required. Many enthusiasts will also be pleased to know that a lighter civic style clutch and civic based axles are used as well.
Bisimoto Heat shield intake gasket
PM for price!
The Bisimoto heat-shielding gasket reduces intake manifold temps by over 50 degrees. This allows a denser intake charge mixture and hence more power.
You do get what you pay for. We have seen a 7hp gain on the stock F22, and another great advantage of it being reusable. Boosted applications gain even more from this mod due to the heat that the turbocharged engines can generate.
Action Clutches
PM for price!
The best kept power transfer secret of the pros! Bisimoto's clutch of choice; made in the USA. For your 90hp to 1000 hp setups, street, strip and drift! The company has been working with local high-performance race shops throughout the US and the UK, mainly with OEM, STREET, DRIFT, OFF ROAD and RACE TRACK setups.
Bisimoto/Arias Pistons
PM for price!
These pistons grace the most powerful all motor, gasoline and alcohol powered sport compact engines on the planet! Race spec pistons feature aluminum wrist pin buttons, ceramic coated domes, moly coated skirts, flow bench designed high compression domes, and can be configured for 2 and 3 ring designs. Shelf units incorporate pin locks. Bisimoto Spec forged pistons are manufactured exclusively by Arias Pistons, with compressions ranging from 10.5:1 to an astonishing 17.0:1. These specialty pistons can accommodate up to 3mm oversize valves and strategically lightened to provide optimal weight savings without compromising strength integrity. Gains exceeding 8% have been documented with this piston technology in comparison to competitor shelf units. Serious inquiries only.
Bisimoto Rods
PM for price!
Bisimoto Spec. Steel rods are manufactured from the very best aircraft quality 4340 steel. Using Autocad 14 technology, the Bisimoto Spec. rods are lightweight without sacrifice of strength. The Bisimoto Spec. steel rods feature 3/8" diameter ARP8740 bolts and have been tested to over 800 HP on a proper tune. Ideal for street, strip, road race, auto-x, time attack and full power competitions...n/a or boosted.
The small end bores feature bronze pin bushings for floating pin applications, with 3 (yes, three) oiling holes: perfect for shelf and custom forged pistons, providing amazing lubrication qualities in the most extreme performance applications.
Bisimoto/Portflow Head Porting Service
PM for price!
We use Portflow and our own proprietory CNC head port profiles to produce the most powerful head packages in the sport compact world!
Here is the link to the our different Head Porting Services: http://bisimoto.net/store/index.php?...&cPath=3_41_65
Bisimoto/Golden Eagle Block Sleeving Services
PM for price!
Get the same strutted/braced sleeves used by team bisimoto: guaranteed not to leak! Manufactured by Golden Eagle manufacturing, they are the choice of our engineering firm, and factory teams from Mazda, Scion, Honda, and Toyota. You deserve the best! We carry the best warranty in the business. For more information: http://bisimoto.net/store/index.php?...dex&cPath=3_42
Bisimoto Aluminum flywheels
PM for price!
SFI spec. 1.1 approved Evolution flywheels are precision CNC machined from aircraft quality 6061 aluminum, and assembled with high-grade quality fasteners. The lightweight unit gives you excellent weight savings, and engine pulse dampening. Available for all D/B/H/F/K Series Honda and Acura engines. LIMITED LIFETIME WARRANTY!!!
Bisimoto Engine Building Services
PM for price!
Due to popular demand, Bisimoto is now offering the epitomy of engine building services to the public. Enthusiasts now have access to the same technology and precision that go into the record breaking Bisimoto fleet of cars. For more information: http://bisimoto.net/store/index.php?...index&cPath=83
Old Sep 4, 2009 | 02:26 PM
Default Re: ~$$$BISIMOTO ENGINEERING PRODUCTS$$$~
New Specials for our favorite customers
Old Sep 4, 2009 | 05:04 PM
Janet@bisimoto's Avatar
Weekend Bump!
Old Sep 8, 2009 | 09:54 AM
Tuesday Bump
Old Sep 8, 2009 | 04:43 PM
BUMP
Old Sep 9, 2009 | 08:32 AM
Hump Day Bump!!
Old Sep 9, 2009 | 05:02 PM
MIDWEEK BUMP
Old Sep 9, 2009 | 06:49 PM
PinoyShadow's Avatar
I have had nothing but positive results and positive interactions with BISIMOTO. There is true research and development done with each product and I am very happy that I am now working with them rather than with all of the other stuff that I used before. 100% VOUCH from me.
Old Sep 10, 2009 | 09:31 AM
^^thank you very much.we really appreciate it
Bump Bump Bump
Old Sep 10, 2009 | 04:43 PM
Evening Bump!!
Old Sep 11, 2009 | 08:55 AM
Friday morning bump
Old Sep 11, 2009 | 02:36 PM
Pre-Weekend Bump.
Old Sep 11, 2009 | 04:41 PM
WEEKEND PUMP
Old Sep 13, 2009 | 07:22 PM
SUNDAY BUMP
Old Sep 13, 2009 | 10:51 PM
keoni96764's Avatar
pm me f2b price shipped to 96720 thanks
Old Sep 14, 2009 | 08:46 AM
Monday Bump!!
Old Sep 14, 2009 | 05:00 PM
bump
Old Sep 15, 2009 | 08:31 AM
morning bump
Old Sep 15, 2009 | 04:31 PM
Evening Bump
Old Sep 16, 2009 | 09:59 AM
Wednesday
Old Sep 16, 2009 | 04:37 PM
Old Sep 17, 2009 | 09:23 AM
BUMP
Old Sep 17, 2009 | 12:53 PM
bump
Old Sep 17, 2009 | 04:43 PM
Evening Bump
Old Sep 18, 2009 | 09:14 AM
Bump for Friday
