Is my crank toast?
Old Sep 4, 2009 | 12:45 PM
johnnyonth3spot's Avatar
Default Is my crank toast?
I dont want to reground the journal I will get a micropolish if its still usable. There is no burr on it just a gouge in the surface will this cause problems with oil clearance or posibly trap particles in my oil under the bearing.
Old Sep 4, 2009 | 01:37 PM
dacrxguy's Avatar
Default Re: Is my crank toast?
uhmmmmmm toast
Old Sep 4, 2009 | 04:57 PM
newbie thinks my crank is delicious how about the opinion of someone that knows about engine building
Old Sep 4, 2009 | 05:49 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Looks like you both love me so take this to heart son.
I personally would not use it. The reason being crankshafts are under extreme pressures and if they are not perfectly smooth all the way across it will cause the bearing to get "ate" up from the gouge on the crankshaft. Even slight scores are enough to chew through bearings. Remember aluminum and brass are not stronger than steel.
Old Sep 4, 2009 | 05:55 PM
thanks I was leaning towards a new one just wanted to make sure, no big loss though I got it for free when I bought my block.
Old Sep 4, 2009 | 06:57 PM
beansandrice's Avatar
I dont care if I get flammed but your really not that bad If you Micro polish it. On the honest the Oil hole is right there too and the crank (at correct clearance) should move freely. Ghetto yes but Toast no.
Old Sep 4, 2009 | 07:03 PM
apekd's Avatar
Yeah its toast. Unless you know someone who could regrind the WHOLE thing and get the right thickness of bearings (which would almost be a waste) its toast.
micropolishing isnt a BAD idea, its just not a good one. The damage to the crank is not enough for micro polishing to take out. and oil can fill the space in, but when pressure is put onto it (say from the pistons power stroke) it will move the oil out of the way and there wil be contact.
Crank is SHOT
End of story.
Old Sep 4, 2009 | 07:05 PM
Well.... Atleast its a good boat anchor.
Old Sep 4, 2009 | 07:09 PM
apekd's Avatar
AGREE!
The weight of that crank should keep you in one spot. OR if you like to go Innertubing then bring it with and drop it where you wanna sit and sip a few beers while waiting for friends
Old Sep 4, 2009 | 10:51 PM
thanks for the replies everyone.
Old Sep 5, 2009 | 07:13 AM
dacrxguy's Avatar
your welcome
Old Sep 5, 2009 | 07:25 AM
angel_i's Avatar
Looks like that is too deep for MICRO polishing.
Old Sep 5, 2009 | 07:34 AM
The gash is deep I was more concerned with it tearing up my bearings if i smothed out the journal.
Originally Posted by dacrxguy
your welcome
thanks for the replies everyone that helped .
Fixed
Ive decided to scrap the crank no more replies needed
Old Sep 5, 2009 | 08:02 AM
DO IT ON ALL FOURS
LOL really? When did you come to that conclusion? They don't even make oversized bearings big enough to fill the void after he had it turned down to get rid of the gouge.
Old Sep 5, 2009 | 08:34 AM
angel_i's Avatar
Thats why the crank is toast.
Old Sep 5, 2009 | 09:06 AM
Reminds me I just had toast for breakfast.
Old Sep 5, 2009 | 07:17 PM
trip-doh's Avatar
I had a crankshaft that I purchased from a deadbeat on Honda-Tech. It was toast. I took it to a place where I live called Spartan Crankshafts. They welded and ground the crank back into spec. It ran me $250.
Old Sep 5, 2009 | 08:01 PM
angel_i's Avatar
^that sucks man. Good thing that it was fixable
Old Sep 5, 2009 | 08:24 PM
DO IT ON ALL FOURS
WOW you actually paid $250 for that, are you crazy? You can get a forged one shipped for under $150... Also everyone knows that a welded and ground crankshaft or camshaft wears a lot faster because not being part of the forging process. Look up metallurgy make ups and you will see how welding effects these properties as well. Also the metal from the weld is not the same from the same forge as the crankshaft.
carlossolorzano
May 30, 2012 06:43 AM
jbrokos307
13
Oct 21, 2009 05:51 AM
bks84
Feb 19, 2006 08:42 PM
Muckman
May 17, 2004 08:33 PM
JDcompman
May 14, 2004 10:49 AM
