Need help wiring a hotrod....
I need help wiring my car,im using a moroso switch panel. I need to know how to wire a ignition switch w/ push button starter if somebody can show me a specific diagram. Need to wire ignition starter fuel pump & fan switch. Needed asap thanks apreciate all the help you can give me....
I don't think there's really any diagram out there ..
Are you running a stock harness ? Got a fsm?
Most of what u mentioned will splice off the ign switch.
Ign, then start signal to push button momentary. Then
every thing else is pretty self explanatory. . .
what EMS are you using? Wiring should be pretty simple. If you are still using a Honda ECU you can pick up a factory Honda service manual and check the schematics in there for how to wire it up.
im still using stock harness but i eliminate some wire u dont use. im using also hondata s300, im just confused in ignition switch......
Honda Crx
Audio / Security / Video
Jul 17, 2006 11:07 PM
T25 civic
Aug 7, 2003 10:32 AM
